Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Daisy chaining extension blocks
    I'm Allen.
    Something like this will help
    https://olsondirect.co.uk/6-way-13a-...-plug-pdu.html
    ! have 2 10 way units
    I'm Stephen.
    Yep, I have been in touch with Olson and they can certainly help - even remove the LED and fit wider brackets. At a price - a pair of 8 way blocks are nearly £200.
    Lynxpower do similar 19” blocks - aluminium chassis but 1.5mm rather than 2.5mm internal wiring.
    I would have to sort out the brackets and LED (is it easy to take that out of circuit) but they would be £50 the pair.
    I feel the latter would do considering the likely load tequirements (less than 500w per block).
    I will take a trip to the DIY store to see what bracketry is available.
    Cheers
    Current kit :
    Music library (FLAC) on IMac or streamed via Qobuz. Fed wirelessly to Raspberry Pi / Allo Digione and into Lyngdorf digital amplification. This handles room correction and drives a pair of Quad 2905 electrostatics.
    I've got a six way, feeding a six way, feeding a 4 way on the A.V system. No issues at all. It probably does compromise the power amp performance a little, but I've no safety concerns.
    I lived in a few old houses with big rooms and only 1 single plug socket. I had six boards daisy-chained in one place for several years with no issues.
    I wouldn't do it with a dedicated audio system unless there was no option.
    I daisy chain some Bennenstuhl 10 way sockets as long as there is not too much switched on at one time. There are only a few things taking priority and it allows me to switch off banks of five and leave other things connected
    Its not ideal but I have around 35 things fighting for plug space in this room. I found a quality block with a quality switch and Im happy with that.
    I'm Stephen.
    Got the two Powerlynx 7 way strips, drilled a couple of pieces of steel to extend the brackets (and sprayed them black) and bolted to the stand uprights using its spare M8 bolt holes. All a bit tidier and now I have three more spare sockets than before 😁
    I would like to disable the neon indicators but access is a bit tight and I dont really know how. In the meantime I sprayed the plastic covers that fit over them black so i dont see them.
    Current kit :
    Quote Originally Posted by Liffy99 View Post
    Got the two Powerlynx 7 way strips, drilled a couple of pieces of steel to extend the brackets (and sprayed them black) and bolted to the stand uprights using its spare M8 bolt holes. All a bit tidier and now I have three more spare sockets than before ��
    You should really try to remove the neon indicators: they are a noise source and covering them up won't change things.
    Quote Originally Posted by Minstrel SE View Post
    I have dedicated ring of 20 sockets for my audio system, yet the most I use would be 12, and that includes electrostatic speakers which need a mains supply and monoblock power amplifiers. How do you manage 35, is your TV/home theatre in the same room?
