Results 1 to 10 of 19
Thread: Setting Tracking Force
    I'm Robert.
    Default Setting Tracking Force
    I'm setting tracking force with digital scale, should anti-skate be on or set to zero ?
    My System:
    CDP - Pioneer PD-91
    I'm John.
    I always set the bias to zero when doing tracking force as I find the arm has a tendency to ''wander'' otherwise.
    Sent by me using an appendage
    SME Model 15/V tonearm, Lyra Dorian, EAR Phono Box.
    Luxman 509X amp.
    PMC 25 23i speakers.
    Innuos/Roon/Qobuz/I-Pad. Oppo UDP-205.
    Cables by Kimber, Yannis and Audioquest.
    Audioquest Niagara. Tube Distinctions Mains power filter. Project RCM. Zerostat.
    Quote Originally Posted by prestonchipfryer View Post
    Agreed.
    I don't have any anti-skate set on mine when I change VTF.
    I'm Stephen.
    Anti skate should be off (0) when setting VTF.
    Always a little further
    I'm Patrick.
    Quote Originally Posted by worrasf View Post
    Would this mean that the bias weight would be completely removed when setting the VTF for a tonearm such as the SME 3009?
    Quote Originally Posted by Simon75 View Post
    Yes, or at least lifted up so the nylon thread is slack.
    I'm Patrick.
    Cheers. They don't tell you this kind of thing in the manual!
    Ah, but vertical tracking force can hardly be vertical with a sideways force acting on the arm. Probably wouldn't affect the tracking weight too much, but would make cuing onto scales a bit hit and miss (literally !).
    Attempting to apply downforce with antiskating force still applied produces an angular force instead of a purely downwards one, meaning results cannot be accurate.
