You'll get a lot more than just good tune from new linn-equipment.
But I've been to many linnstores myself and wonder why it sounds so bad compared to having the things at home.. quite crappy listening rooms often i think, weird reflections, what you would never get at home in a normal living room.
In order to get the feeling that the musicians are performing in front of you, you need to get the musicality correct. Because that's one of the important aspects of going from a blurry playback to an open window, but of course you need resolution, details, soundstage and punch as well for that.
What's the difference between sound and music? It's timing pace rhythm..
What's the difference between a good and a bad band... timing, that the musicians are playing together, swing!.
It's the same between different hifi equipment, on many stereos the band isn't playing nearly as tightly as they were in the recording studio. Phase shift or whatever is the technical explanation thing behind this, timing differences between different frequency, but also if the speakers are not placed correct( I have mine tuned in on the millimeter), you'll get the sound reflections in the room disturbing the timing, and making it less an open window to the music.
Many people even are having their sub woofer coming milliseconds after and they're noticing anything, and is just leave the room with headache And they still think their system is transparent Well it might be quite transparent in the tone but, not in the essence of the music, the playing together. How many know that if the sub is lagging after the drummer will not sound as good as he was in the recording studio.
And if there are timing distortions, the sound is crinkled in some way.
Even diffrent cables are crinkling the sound in diffrent ways, and again, Linn black is the best I've heard here. I've been doing some blind testing together with a friend here.
Another problem with that you want the musicians to sound if they are standing in front of you is that, everyone on the stage have their separate mic cable going to their instrument, so through the mixer if not panned exactly everyone will sound if they're standing in the middle. So the soundstage is an artificial creation, because it's not recorded that way. Except if you don't record it with only two microphones, from the audience. Buth then again if it's a rock concert you'll get lots of weird echoes..
But you probably already new that..
If you'd had a 100 00€ preiced linn equipment for two years and then went back and listened to that horn equipment, you probably would think, where the heck the music went, even tough the sound probably was nice
Themis: The tune method and the PRAT were developed back in the 70's some time.. i think this link explains some of it..
http://www.tnt-audio.com/edcorner/prat_e.html
