[B]Class A , A,B Amplification[/B\]
Marantz PM4
Turntable
CD Transport & DAC & PSU
Loudspeakers
Tannoy 615 MK2
Speaker Cable , Digital Coax , Interconnects
QED Speaker Cable , Chord Coax Digital , Nakamichi Interconnect , Belkin Interconnect
or in hi-fi inflation more like four grand...
They look ace. I like the look of the Lux too. Classic combination.
Yes, Luxman + Tannoy = synergy
Marantz PM4
Turntable
Loudspeakers
Tannoy 615 MK2
Well a little bit of fun purchased a £20 Little Bear "Nobsound" P5 1 - Passive Pre , Buffer for some fun the question is its a 100K ohm Impendence so which power amplifier could be suitable - Quad 405 , Linn LK 85 or Technics SE A909S
Thoughts?
Many Thanks
Marantz PM4
Turntable
Loudspeakers
Tannoy 615 MK2
Is that the one that has RCA and XLR in and out? I'm not sure it's genuine balanced but have heard good things for the money.
Edit: just saw you said buffer do I guess not, does this have pair of little valves? You want to upgrade them to equivalent Russian types to hear it at its best and they only cost a few quid
Sent from my BKL-L09 using Tapatalk
Hi
One in put and One output RCA jacks - Will upgrade the valves in due course - Cute thing -
Marantz PM4
Turntable
Loudspeakers
Tannoy 615 MK2
Morning All
Appears my left side tubes need replacing on my LA Audio A30 think they are due for replacement as they must be up to 10,000 hours usage - I have 4 spare Mullard EL 84's - So off to the tech to fit some Mullard EL 84's presuming They will also need to be re biased too another job for the Tech
The joys of Valve kit -
Marantz PM4
Turntable
Loudspeakers
Tannoy 615 MK2
Changed over them over - One is not lit as well as the others so do i need to source another EL 84 - Off to the Tech
Marantz PM4
Turntable
Loudspeakers
Tannoy 615 MK2
