I'm hoping its just dust in the coil gap - No where near as bad today the rub is not around the full circumference of the cone but mid way either side i have done the 180 turn -
They have been booked in mid march with my Tech -
Bi Amplification
Quad 33 with current Mod for CD
2 Quad 303 Bi Amped
Turntable
CD Transport & DAC & PSU
Loudspeakers
Tannoy 615 MK2
Cassette
Goodmans GSW 435
If it's more pronounced to one side, it's cone sag and may correct itself after rotation, a warm environment helps.
Bi Amplification
2 Quad 303 Bi Amped
Turntable
Loudspeakers
Tannoy 615 MK2
Cassette
Goodmans GSW 435
You don't have much luck with gear do you Dan, I hope you get all your stuff cheap.
Sent from my BKL-L09 using Tapatalk
Bi Amplification
2 Quad 303 Bi Amped
Turntable
Loudspeakers
Tannoy 615 MK2
Cassette
Goodmans GSW 435
It is but I always try things out first. Actually, I did until Covid!
Bi Amplification
2 Quad 303 Bi Amped
Turntable
Loudspeakers
Tannoy 615 MK2
Cassette
Goodmans GSW 435
Yeah bit of a trek that!
Sourced a NOS 2528 cone from the states if needed for a Re cone - but here's the question what's the best glue for my engineer to glue the rubber surround to the basket?
Thank you
Bi Amplification
2 Quad 303 Bi Amped
Turntable
Loudspeakers
Tannoy 615 MK2
Cassette
Goodmans GSW 435
I've used Aleene's Tacky Glue on Tannoys in the past. It's water based and mating faces remain movable for a while, works a treat! Apply it with a small art brush. It can be thinned with water if required.
If you don't have a spare, separate the trim ring from the front of the rubber cone surround very carefully for re-use before removing the cone itself. The rear cone spider is held in with screws, make sure the washers don't get into the coil gap or you'll have big problems.
You don't need to remove the gauze dust cap and shim the coil central as some suggest. It is easy enough to get right by feel and a bit of judicious jiggling.
