Page 37 of 89 FirstFirst ... 2735363738394787 ... LastLast
Results 361 to 370 of 885
Thread: The System
  1. #361
    I'm Dan.
    In lockdown changing gear daily to give them a run
    Today's lash up
    Creek 6060 integrated as a Pre
    Quad 405 Power Amplifier
    Kef Reference 103 Speakers
    Rega Planar 2 Turntable / RB250 / Ortofon Super 10 Cartridge
    Sounding Fantastic
    Spinning some vinyl and going through collection sure have some nice stuff Prog / Reggae / Soul / Disco / Jazz / Rock anything in between happy days most proud of the gear I own too
    Pre & Power
    Technics SUC 909U & Technics SE A909S
    Turntable
    CD Transport & DAC & PSU
    Loudspeakers
    Tannoy 615 MK2
  2. #362
    I'm Dan.
    Morning Tunes
    Nad 3020
    Philips GL 561 Full Rangers from 1967 were £10 Sound superb
    Rega Planar 2 TT
    "Pink Floyd - Wish You Were Here"
    Rather Stunning
    Pre & Power
    Turntable
    Loudspeakers
    Tannoy 615 MK2
  3. #363
    I'm Dan.
    Tonight's lash up
    Quad 33 / 303
    IAS Hamble Speakers - Back loaded Horn
    YouTube App
    And a Few Ciders
    Impressive
    Pre & Power
    Turntable
    Loudspeakers
    Tannoy 615 MK2
  4. #364
    I'm sorted.
    Quote Originally Posted by dantheman91 View Post
    And a Few Ciders
    Alcohol, nature's upgrade! Cheers Dan
  5. #365
    I'm Dan.
    Cheers Roy -
    Pre & Power
    Turntable
    Loudspeakers
    Tannoy 615 MK2
  6. #366
    I'm Dan.
    Hi
    I want to use a Technics SU-C909U as a pre with the quad 405 only trouble is the pre takes power from the technics 909 power amp is their a way so I can just power the pre to use with the 405. Interesting
    Pre & Power
    Turntable
    Loudspeakers
    Tannoy 615 MK2
  7. #367
    I'm Andre.
    I prefer the Technics class AA amps to the '405' current dumpers
  8. #368
    I'm Rob.
    There might be two ways to do this. The power connection from the power amp to the preamp appears to be a DC feed as the connecting lead looks like it has DC power plugs on it (this is from looking at pics by googling) If you have a multimeter you could measure the voltage from the socket on the power amp and get a separate supply to pwer the pre.
    OR you use it as is and take the L & R channels from the Pre-out sockets on the rear to the inputs on the 405. The power amp will of course remain powered up, but that should not present a problem unless Technics say that it should not be run without a load attached, i.e speakers.
    https://youtu.be/ZCBe7-6rw4M
  9. #369
    I'm Dan.
    Cheers Pal - Will give it a try
    Pre & Power
    Turntable
    Loudspeakers
    Tannoy 615 MK2
  10. #370
    I'm Dan.
    Hi
    Digging out my Sony La Scala Pre amplifiers can these be used with any power amp if I use the output for the SA S1s? ��
    Cheers
    Pre & Power
    Turntable
    Loudspeakers
    Tannoy 615 MK2
