Page 18 of 89 FirstFirst ... 816171819202868 ... LastLast
Results 171 to 180 of 885
Thread: The System
  1. #171
    I'm Dan.
    Quote Originally Posted by Beobloke View Post
    No, Dan - do not use them like this. They’ll sound rubbish and you may well damage the voice coils.
    Tested and all working...
    PS the foam is still intact and hard but their are cracks in places but will put to one side do you know of anyone that can fit new surrounds..?
    Pre & Power
    Technics SUC 909U & Technics SE A909S
    Turntable
    CD Transport & DAC & PSU
    Loudspeakers
    Tannoy 615 MK2
  2. #172
    Quote Originally Posted by dantheman91 View Post
    Speak to Wembley Speakers. They will probably have suitable surrounds available and can fit them.
    The ALS40 are good fun. Very fruity bottom end, you should be able to shake the house quite nicely with those.
  3. #173
    I'm Dan.
    They were less then £50 from a lady doing a house clearance..I have emailed Wembley speakers and a couple of other local engineers...
    Pre & Power
    Turntable
    Loudspeakers
    Tannoy 615 MK2
  4. #174
    I'm Dan.
    I have found someone local to fit the surrounds hopefully they will be up and running in a couple of weeks...
    Pre & Power
    Turntable
    Loudspeakers
    Tannoy 615 MK2
  5. #175
    I'm Dan.
    Foams ordered should be up and running week after next..
    Pre & Power
    Turntable
    Loudspeakers
    Tannoy 615 MK2
  6. #176
    I'm Dan.
    Marantz PM4 and Audio Note ANJ/D Speakers
    A good match?
    Pre & Power
    Turntable
    Loudspeakers
    Tannoy 615 MK2
  7. #177
    I'm Dan.
    Foams are here for the IMF's
    Can anybody advice on how i can fit them myself?
    Pre & Power
    Turntable
    Loudspeakers
    Tannoy 615 MK2
  8. #178
    Very carefully!
    Seriously, if the cones move back and forth freely without the coils rubbing, don't worry about shimming as the rear spiders are still concentric to the magnet gap.
    Just clean the old foam off the chassis and cone carefully. Probably best just scraped off with a craft knife or similar.
    Bond the new surrounds evenly to the cones first as you can then move them around a bit on the chassis lip to centralise them. If you're not sure about positioning, hold them in place with a few blobs of BluTak until you're happy, then tack glue them in three equally spaced positions, allow to dry then bond the rest. Use a small art brush to apply adhesive. Most seem to use water based PVA, I prefer Aleene's Tacky Glue, also water based.
  9. #179
    I'm Dan.
    Default Question...
    Thanks Geoff
    Does the O ring need to come off to glue the foam to the chassis on the out edge...?
    Pre & Power
    Turntable
    Loudspeakers
    Tannoy 615 MK2
  10. #180
    Thanks Geoff
    Yes. I take it you mean the trim ring. Remove it by slipping a blade under it and separating it gently from the chassis rim. Clean it carefully for re-use. It's probably fairly fragile.
