Hello gents, I just joined the forum recently. I have a KAB-modded Technics 1200 Mk2 'table on order, and have just purchased a Denon 103, which I'm also sending on to Zu for their modification. I have read that there may be a problem setting VTA on the Technics with the stock 103 - does anyone have any experience with the Zu version? Would it still require a spacer or some other bit of rig to set it up properly in the headshell so as to attain proper height?
Lots of good information on the forum - part of the reason I decided to search out the Technics was due to the interest being shown this TT. This represents something of a leap of faith for me, as I've only heard the stock version. I liked in general what I heard of it stock, and am getting most of the mods via KAB: Isonoe footers, power supply, tonearm rewiring, strobe disabler, fluid damper, and having the dustcover set up without the hinges so I can completely remove it during play.
I've also read some posts regarding a significantly heavier counterweight used with the Zu Denon, due to its nearly 14-gram weight after modification. Which are you guys using there?
Thanks for the help, and I appreciate the welcome given me here!
