Page 15 of 19 FirstFirst ... 51314151617 ... LastLast
Results 141 to 150 of 182
Thread: Ker pow!!!
  1. #141
    And I agree, however; when we look at how each [valve and solid state designs] deals with the constant impedance fluctuations, over frequency response; a valve amp will at least try to maintan the correct power at its output.
    "Flat response" loudspeakers will only give you a flat response if driven from a constant voltage source.
    Nikola Tesla
    www.tubedistinctions.co.uk
    Matthew 5:10
  2. #142
    Quote Originally Posted by anthonyTD View Post
    I should also take this opertunety [while its fresh in my mind] to stress why when it comes to wide power bandwidth [where valve amps are concerned] a good quality output transformer, with a decent amount of iron is necessary!
    Unless you use and OTL amp which means you don't have any of the problems associated with big lumps of iron
  3. #143
    Ahh, but then first of all; you are limited to the type of valve you can use in the output stage, due to the low impedance needed to drive a real world loudspeaker direct, unless multiple valves in parrale are used, and then you have all the negatives of matching said valves, and the type of circuit, and finally, the risk of directly connecting these high voltage devices [which often fail being run in this manner] to your precious loudspeakers! That's not to say though that OTL's cant be made to work, and perform exceptionaly well, they can, but for me, and in my honest opinion, the negatives out weigh the positives.
    Nikola Tesla
    Matthew 5:10
  4. #144
    Unless you use MOSFETs in the output stage.?
  5. #145
    Are we talking Hibrid designs James ? if so, that's a diffrent story.
    Nikola Tesla
    Matthew 5:10
  6. #146
    Yes Anthony, I am talking of the Croft Series 7 power amplifier.
  7. #147
    Ok,
    Hibrid designs can work very well, and combining both topologies, you can overcome some of the short comings in each,[you just have to choose what those are, and what you want to achieve] in my hibrid design I chose to go solid state front end, valve output, where as Glenn, and others decided on the reverse, either way; both can be very rewarding.
    Nikola Tesla
    Matthew 5:10
  8. #148
    All this of course ably shows that there's no such thing as the 'perfect amplifier', so as with anything else in audio, all you can do is choose your compromises!
    On the subject of valves, however, I will say (as experience has shown it) that hybrid and/or OTL designs, certainly those I've heard, no matter how well designed, don't sound like the best valve amps should, which is why, as much as I acknowledge what they're capable of doing well, I haven't gone down that road.
    It's an old saying in audio, but quite simply, there's no 'free lunch', when attempting to build an amplifier that on paper is seemingly devoid of any of the vices of either valve or solid-state technology, or is touted as being the 'best of both worlds' (as often hybrids designs are), because in reality that just doesn't exist. You're likelier to end up with a 'master of none'...
    That's because as soon as you address what's worst about valves or transistors, by attempting to 'fix' it, and in turn trying to make it do what the opposite is better at, you automatically compromise (in some way) on what the technology itself [valve or transistor] is inherently BEST at! Hence, no 'free lunch'
  9. #149
    Ah I see Anthony beat me to it!
  10. #150
    Bigman80 Guest
    On the subject of valves, however, I will say (as experience has shown it) that hybrid and/or OTL designs, certainly those I've heard, no matter how much they excel in certain areas, don't sound like the best valve amps should, which is why, as much as I acknowledge what they're capable of doing well, I haven't gone down that road.
    It's an old saying in audio, but quite simply, there's no 'free lunch', when attempting to build an amplifier that on paper is seemingly devoid of any of the vices of either valve or solid-state technology, or is touted as being the 'best of both worlds', as in reality that just doesn't exist.
    What kind of valve amp would sound "as it should"?
    Freely available and not the price of a used car please lol
