Page 37 of 60 FirstFirst ... 27353637383947 ... LastLast
Results 361 to 370 of 591
Thread: SPOTFIRE new interconnect review
  1. #361
    Bigman80 Guest
    Quote Originally Posted by Domg View Post
    I’m thinking of re-cabling after recent addition of monoblocs. My hifi cabinet is to one side and I could place the monoblocs under the speakers if I had long (4m + 2m) interconnects and short 1m speaker cables. I guess long interconnects would need to be quite low capacitance and am thinking of using Neotech NEI-3001 mkIII with with some msaudio rhodium rca’s I have. Would the Spotfire cables be a good alternative for long cables - any other suggestions also welcome. My preamp is a Croft Epoch and speakers are Troels design SBA MW19 - quite evenly voiced and balanced sounding monitors.
    There is a lot of great cable out there, Neotech make some of the good stuff.
    You need to decide what you want from the cable because everything about it will be an influence. Dielectric, conductor material, length, RCA plugs, it all makes a difference.
    Personally, I don't like silver plated cable, I doubt the HF to be exaggerated on nearly all the ones I tried but I never tried this one so can't say.
    Silver cable, in my opinion, is very difficult to get right. Again, I've never had a silver cable I liked. I've tried a lot of them too.
    My personal opinion is that a cable with the least amount of "imperfections" in the conductor will do a better job than a cable that's intrinsically flawed in its conductor material. I also don't like cables with with small conductors.
    The SPOTFIRE were specially selected because they tick all of my requirements.
    I haven't made a pair that are 4m long and therefore I haven't got an idea about the Capacitance of the cables, I can find out though.
    If you want a seriously low capacitance cable, there's Van Damme LO-CAP & Sommer carbokab which tick the boxes.
    You're welcome to join the loan list for the SPOTFIRE but they are 1m long so may not work out.
  2. #362
    Bigman80 Guest
    The SPOTFIRE are 160pf/m.
  3. #363
    I'm Neil.
    Pretty normal for a coax cable.
  4. #364
    Bigman80 Guest
    Can't see any reason for them not to be ok at 4m as long as the preamp is active.
  5. #365
    I'm jamie.
    the spotfire tonearm cable arrived today mate,cheers!
    im giving it a spin now,first impressions are i like it ! very well made,lovely quality rca's,id say more detail is coming through right off the bat,background noise appears quieter too
    My System
    John Wood KT88 Amp.
    Paradise Phono Stage
    Sony TTS-8000 Turntable.
    PMAT-1010 MK6 Tonearm.
    Ortofon Cadenza Bronze
    Sony X555ES Cd Player
    Yamaha NS1000m Speakers
  6. #366
    Bigman80 Guest
    Thanks for the comments mate.
    Give it some hours and I think you'll be happier still.
  7. #367
    I'm Sandro.
    Can I get in the loan list please
  8. #368
    Bigman80 Guest
    Quote Originally Posted by Bksabath View Post
    No problem!!.
  9. #369
    Bigman80 Guest
    List Update
    Now - Ian7633
    Next - Jamie123
    2nd - docp
    3rd - Idlewithnodrive
    4th - rmcim626
    5th - VanDerGraaf
    6th - Bksabbath
    7th. - Domg
  10. #370
    I'm Dominic.
    The signature of a Spotfire cable will likely be similar for a 1m or 4m cable, so it would still be great to try before I buy. Please add me to the loan list too.
