AC POWER
AMPS
SPEAKERS
Wharfedale Evo 4.4
DAC
TURNTABLE
PHONOSTAGE
DIGITAL
MUSIC PLAYBACK
Ipad Roon Remote.
SPEAKER CABLES
INTERCONNECTS
Check the cap models, but yup they look identical to stock.
I'm Gene.
On the power supply board - first image on this site - all the larger caps are ACON. In the second image, the analog board, the big caps on the left are ACON x 2 up front and ELNA the six behind. On that board, the two small caps front left center are ELNA and ACON, while I think all the rest of the little ones are ELNA. Since the mod is described as cap focused, it's good to be sure about those (not that changing a few caps should cost $395).
AC POWER
AMPS
SPEAKERS
Wharfedale Evo 4.4
DAC
TURNTABLE
PHONOSTAGE
DIGITAL
MUSIC PLAYBACK
Ipad Roon Remote.
SPEAKER CABLES
INTERCONNECTS
I'm Gene.
Our original power boards look identical.
OCXO femto clock upgrade done last night over at Tirna Electronics.
Quick listen this morning before work at very low volume.
Immediately different sounding...the clock upgrade has changed things significantly.
Good stuff.
Follow up installation pics and further impressions when I have a few days with it.
AC POWER
AMPS
SPEAKERS
Wharfedale Evo 4.4
DAC
TURNTABLE
PHONOSTAGE
DIGITAL
MUSIC PLAYBACK
Ipad Roon Remote.
SPEAKER CABLES
INTERCONNECTS
I'm Gene.
From what I'm told, the OCXO is actually not a femto, and it is not presented as such on Oppomod's site. A femto is a chip that puts out different clock frequencies to a clock. The OCXO is just a type of oscillating clock with its own frequency.
Uhm...ok?
Femto, as well as being a brand name, is a unit of measure...nano...pico...femto...relating (in this case) to clock accuracy measured in ppm.
Whether oven controlled or temperature controlled clocks, it doesnt matter in this case.
The Oppomod clock board generates both 25 and 27 Mhz by the way.
AC POWER
AMPS
SPEAKERS
Wharfedale Evo 4.4
DAC
TURNTABLE
PHONOSTAGE
DIGITAL
MUSIC PLAYBACK
Ipad Roon Remote.
SPEAKER CABLES
INTERCONNECTS
Femto...sounds like a fizzy drink
