Page 5 of 13 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 123
Thread: Quad ESL 57s
  1. #41
    I'm Dan.
    Hi Dennis
    These ones are what i need....
    https://www.google.co.uk/search?q=bu...bE2wpkFrl3RKM:
    Cheers
    Bi Amplification
    Quad 33 with current Mod for CD
    2 Quad 303 Bi Amped
    Turntable
    CD Transport & DAC & PSU
    Loudspeakers
    Tannoy 615 MK2
    Cassette
    Goodmans GSW 435
  2. #42
    Bulgin three pin mains line socket.
    https://www.ebay.co.uk/itm/Bulgin-3-...gAAOSwmLlX~54z
    Make sure the keyway is the same. I think there are more than one type.
  3. #43
    I'm Dan.
    Hi Geoff
    Been thinking about these too being a novice does anyone have the dimension of the original Keyway i presume this is the size of the pins?
    Thanks...
    Bi Amplification
    2 Quad 303 Bi Amped
    Turntable
    Loudspeakers
    Tannoy 615 MK2
    Cassette
    Goodmans GSW 435
  4. #44
    The slot and key on the side vary If I recall. One being squared and the other rounded, as in the ebay piccie.
  5. #45
    The Bulgin cable-mounted sockets are no longer made (and are actually outlawed by the EU), but do occasionally come up for sale on eBay for around £15 apiece.
    If you are going to have One Thing Audio service your speakers, it would be a good idea to have them change the Bulgin mains connectors for the current IEC type.
    I'm Dan.
    Hi Barry
    I have looked at OTA and the IEC connectors are £9 i think i will go with this option they just got to get someone to fit them...
    Keeping me busy
    Bi Amplification
    2 Quad 303 Bi Amped
    Turntable
    Loudspeakers
    Tannoy 615 MK2
    Cassette
    Goodmans GSW 435
  7. #47
    Quote Originally Posted by dantheman91 View Post
    Hi Geoff
    Thanks...
    Those Bulgin 3-pin connectors are too small. The Quad 57s use these: https://www.ebay.co.uk/itm/Bulgin-3-...sAAOSw0BNakWlG. Hopefully you will be able to find a pair for a far more reasonable price.
    I'm dave.
    try using these https://uk.rs-online.com/web/p/produ...E&gclsrc=aw.ds It is an IEC socket that is a drop in replacement for that Bulgin connector
    You may have to file a couple of mm to make it fit
    Dave
    Any tool can be used as a hammer but a screwdriver makes the best chisel
  9. #49
    Me personally, if the panel mounted Bulgin plugs are intact, I'd leave them be and use the matching line sockets if available.
  10. #50
    Dan if you get a nice, properly working, pair of 57's, and can give them the space they need, they are absolutely lovely
    I had a pair years ago powered by Quad 33/303's and loved them to bits and if I could have fitted a pair into my current room I would have purchased another pair but they are just too wide for the the space I now have
    Unfortunately a lot of 57's for sale will have problems with their panels either arcing or other nasties but if you've found a good pair you are in for a real treat
    Bev
