Lots of great advice. I'll arrange a Mafia visit once the decorating is finished and I save up enough to buy in food for the day
I'm tony.
Mike,
PM sent....
IME, valve amp performance is 90%+ about the circuit & transformer design, and only a few % about the particular valves utilised. For instance, Radford and EAR both have (very different) designs that use EL34s, both giving results superior to the majority of 'bog-standard' KT88 amps. Similarly, the MacIntosh 275 uses a different circuit design to raise it's performance above the norm. for KT88 push-pull amps.
My Leben power amp has the facility to re-bias across a wide range of power valves (KT120, KT88, KT66, EL34, KT77, 6L6GC, 5881, 350B, etc), and although I haven't tried them all, there is a lot less difference than most people would imagine with the ones I have tried, the overall performance being overwhelmingly determined by the circuit topology and the o/p transformers. In fact, I suspect a blindfold test would show it'd be quite difficult to reliably, repeatedly, identify which valves were being used.
Indeed, but the chosen valves dictate (to a significant degree) the design of the circuit!
Therefore, one is intrinsically linked with the other...
No doubt, but do the same test with separate amplifiers, each one designed to optimise the characteristics of the chosen output valves (through circuit design and transformers used), and the results would be rather different....My Leben power amp has the facility to re-bias across a wide range of power valves (KT120, KT88, KT66, EL34, KT77, 6L6GC, 5881, 350B, etc), and although I haven't tried them all, there is a lot less difference than most people would imagine with the ones I have tried, the overall performance being overwhelmingly determined by the circuit topology and the o/p transformers. In fact, I suspect a blindfold test would show it'd be quite difficult to reliably, repeatedly, identify which valves were being used.
You'd need to be deaf not to hear the difference! There's a lot more to hearing the true capabilities of any output valve, KT88, EL34, or whatever, than merely re-biasing them in the same circuit... That's especially true, in the case of KT150s, because of their electrical demands.
I like KT88s/120s and 150s in P/P amps because I like a bit of power (at least 30w), because the added 'grunt' has a beneficial (and very valuable effect for me) on the music
No, I don't think so. Take for example a standard push-pull output with grid bias - you could make that with any type of output valves. Same goes for push-pull with cathode bias, or for single-ended output. Pretty much any circuit type could be implemented with any type of valve.
True, there are some restrictions though. You can't make an ultra-linear output stage with triodes for example.
Anyway, I agree that getting the details right is more significant than the broad-brush view that a particular valve type has an inherent sound.
Yup, that's what I was referring to. Also, there's no doubt that if the circuit is designed to *optimise* the electrical parameters of a specific output valve, better results will be obtained than when that's not the case - as I've heard it for myself!
KT150s, for example, require certain types of output transformers (and the right circuit) to give of their best. The reality of the matter is contained in your last sentence: the devil is always in the details
I'm Dennis.
I muse this thread with both interest and a failure to understand it.
I have built many valve amps from the late 60s onwards, and have not used one since about '74. My feelings are that in general they have so many disadvantages that they have technically been surpassed by bipolar SS amps; inefficiency, aging changes, microphony, limited power availability, low damping factor, and at best slightly under 0.1% distortion, but I accept that a good transformer can make the deal, (Partridge), and that they look lovely.
So unless there is an obvious, or even and inference of better sound, I could not consider a valve amp now, and I am left in a quandary about what seems to be this great divergence of perception and taste.
I've even gone Icepower for God's sake - really against every instinct in me, especially when considering the poor reports on switching power supplies.
Hunter S Thompson
Well, Dennis, that's the problem with adopting an 'objectivist' approach to audio, and attempting to use numbers to determine sound quality... Thankfully, there's a lot more to making a piece of equipment sound good (with music) than measurements alone, which only ever tell part of the story.
And so when you're only in possession of part of the story, it's no wonder you fail to understand the full 'plot'...
