My soldering iron is a cheap one and I find it doesn't get hot enough at the tip. Its a 30watt model. Are the 60w ones better or should I go for a brand name?
Jerry
Hifi: IPL transmission line floorstanding speakers, Squeezebox Touch, Denafrips Ares 11 DAC, DCB1 Pre-amplifier, Croft Series 7 power amp.
Custom Hifi cables HA10SE headphone amplifier and Hifiman HE-400 headphones.
AV system: LG 55B7, Denon AVR -x2300w receiver, Quad 12L (front) 11c Centre and 11L rear . Velodyne DD15 subwoofer.
I'm Peter.
I think general advice on soldering irons would be really helpful. I would like to consider the possibility of doing my own DIY stuff, but I have no idea about soldering irons, what to get, how they work, and all that stuff. I hope Jerry won't mind if I ask that responses are a bit wider in their scope, and perhaps take a more simple, layman's tone. (Or maybe I should just start a new thread?)
Peter
There's just no substitute for good old practise.
Have a read here, and get stuck in!
My own set-up is quite simple.
http://www.rapidonline.com/Tools-Fas...pply/32689/kw/
http://www.rapidonline.com/Tools-Fas...nges/30437/kw/
http://www.rapidonline.com/sku/Tools.../61556/85-4850
It might look expensive at first but compared to some it isnt!... Will last for years and years too.
Shian7
Kudakutemo
kudakutemo
ari mizu-no tsuki
Though it be be broken -
the moon on the water.
- Choshu.
I'm Peter.
Jerry
Have a look on ebay under soldering station - 50w Variable Temperature Control Soldering Station Iron (appears to be Maplins ex stock) for £12.99. You can buy various tips for it as well.
Should be good for most jobs unless it is those tiny surface mounted items then you will definitely need a flat tipped bit for it to go with the hands of a surgeon and eyes like a bat - sorry eagle.
Regards
Chris
I've edited my post above to show the equipment I use...
Shian7
Kudakutemo
kudakutemo
ari mizu-no tsuki
- Choshu.
Nice stuff Mike for anyone who intends to do a lot of mods or building. Cheapo ones are fine for small projects and a bit of tweaking. My own Maplins one has lasted nearly 5 years without any probs.
Not so much the type of iron but learning the right way and a bit of trial and error.
Regards
Shian7
Kudakutemo
kudakutemo
ari mizu-no tsuki
- Choshu.
https://youtu.be/ZCBe7-6rw4M
