Fezz Audio Titania *Ex-display*
Extremely powerful and dynamic. Plays openly and with gusto, yet with a remarkably neutral tone. This amplifier constitutes a reference point, a benchmark in the area of tight bass control, and positioning of the virtual sources. Titania – This is simply a Titan of Sound.
Type: stereo vacuum tube amplifier
Max. output power: 2 x 45W
Circiut type: Push-pull AB1 Class
Output impedance : 4Ω / 8Ω
Inputs: 3 x RCA
Harmonic distortions THD: < 0,2%
Frequency response: 18Hz-103kHz (-3dB)
Power consumption: 180W
AC fuse: 3,15A T
Net weight: 17,5 kg
Dimensions: 420x410x175mm
Tubes: KT88 x 4 (power output), ECC83 x 2 (pre-amp & drivers)
Bias adjustment type: manual
Our ex-display unit is gloss red.
Tags for this Thread
- You may not post replies
- You may not edit your posts
Forum Rules
