Page 12 of 16 FirstFirst ... 21011121314 ... LastLast
Results 111 to 120 of 153
Thread: Rexton's Valve System - Upgrade Blog
  1. #111
    Ya, muchacho, and sounding fabby-doodle!
    Good news!
    Same on mine too. I need x2 ECC83s and x2 85A2s
    Not sure how different the ECK82s are but I'd imagine the gain being lower with an 82. I remember trying ECC82s in mine once but didn't get on with it. The ECC83s are the only option IMO... Gives it much more Oooomf!
    Joe, interesting comment. What you say makes some sense. I'd have to do a little more poking around with respects to what your claiming i.e. more/less gain with the ECL82/ECC82 valves. You really need someone like Alan or Glenn to discuss the implications of the different valves in the circuit. This could be something I need to look into.
    PRE
  2. #112
    I'm Josie.
    Good news!
    Yep.. I'm no expert on the techy side of valves. Its just what I've found out in the past.
    Sent from my 9001X using Tapatalk
    Tannoyista.com
    - Audio Equipment Reviews
    Facebook
  3. #113
    Ladies and Gentlemen contact has been made.... Potentially massive upgrades for the Croft and 301! Stay tuned.
    PRE
  4. #114
    Good stuff... Who's doing the mods then - Glenn or Alan?
  5. #115
    Just planning a clear path forwards with respect to what I want done. I'm still researching a few options. I'll spill the beans when due-diligence has been completed.
    PRE
  6. #116
    Lol - nicely swerved... Have you ever considered entering politics?
  7. #117
    he couldn't get used to the underwear
    The Valve System Pt VIII - More rolling....
    When call me a copy cat but I bought a pair of these
    I'd never seen them before Marco mentioned them so I thought what the hell. They should arrive soon.
    The Croft is now getting modded again, but not until next year. It looks like I'll be getting another box to add to the rack but things should hopefully be improved. I can't see things moving forward with this until March 2021 at the earliest but I can start and compile a "wish" list of mods.
    The 301 may also get some more attention in the form of a chassis stiffener / damper and a new plinth specifically made from Permali. The plinth will hopefully incorporate decoupled motor and decoupled tonearm pods and maybe a sprung based base board. This is all pie in the sky at the moment and I;m hoping the get design finalised over the Xmas break and start prototyping sometime in January.
    That's about all so far....
    PRE
  9. #119
    RCA 6SL7GT's no landed, now import charge! YAY! Bit noisy at first no quietened down a bit. I'm going to spend some time weighing these up. In the mean time I might have some more valve rarities from the US of A, depends on if I when the bid......
    PRE
  10. #120
    ECL82 is a triode/pentode in the same glass, not sure what Glenn is using it for in your preamp Andrew, as for the diffrences, ECC83, amplification is 100 per side, ECC81, around 55 amplification per side, ECC82, around 22 per side etc, in much equipment [check with Glenn] you can use an ECC81 with good affect, which is a good compromise between an 83, and 82, as far as gain etc.
    Its not only about the amplification though, both ECC81, and ECC82 also have a higher current drive capability than an ECC83. top military version of the ECC81 is the CV4024, or M8162.
    Hope this helps.
    A...
    Good news!
    Nikola Tesla
    www.tubedistinctions.co.uk
    Matthew 5:10
