I own a Imac and now have Amazon Prime that includes music
Being a complete digital numpty what do I need to get the music out of my mac and into my hifi
Please go easy on me
I'm Allen.
I'm mark.
Lots of ways, headphone socket (3.5mm) to phono cable is simplest, dac with USB input, or you can use the same 3.5mm socket and a digital optical cable into a compatible dac.
Dac options are long and varied best discussed with some idea of budget?
No connection to the seller, but I had one of these
http://theartofsound.net/forum/showt...y-Ci%FAnas-DAC
Plug n play connection, as analogue as I've heard around that price range.
Bluetooth 4.1/4.2 transmitter and reciever will work also if you dont want cables. These are low latency almost cd quality sound
I use a Mini Toslink to Toslink Optical Cable into a DAC.
This type. http://www.ebay.co.uk/itm/like/15143...D1297420703380
^that is what I use
TOSLINK or USB to SPDIF is the way to go.
I'm Allen.
I'm Allen.
I'm mark.
