Nope ha ha, it's this one! https://uk.farnell.com/multicomp/g20...0mm/dp/1526678
Cable glands on each end. One will be hardwired into my mains block, the other side will have a plug on it.
https://uk.farnell.com/lapp-kabel/53...rey/dp/1178870
https://uk.farnell.com/lapp-kabel/53...rey/dp/1178912
We've all still got a way to go to catch up with Marks'.
Mine doesn't even have a box
I'm Deleted.
Looks cool Mark, take it you used the plug socket for your Hydra?
I'm Deleted.
Yes, that's right Neil - hence the Cerberus name, to keep the theme with the Hydra . pretty much my whole system is run from it.
Account Deleted
That's encouraging RE running your whole system from it, because I intend to do the same.
Have been looking into a hydra too, but don't want to compare 2x fundamental changes at the same time, so will try the DC blocker first, then look at a Grahams hydra to replace the mains block & cables.
