Results 21 to 30 of 42
Thread: OMG, Life Will Never Be The Same Again, I’ve Just Been Wammed!
  1. #21
    Limited edition run, so not so many pairs to be sold to recoup all that R&D time. Although I grant you at a million bucks they are into Veblen goods territory.
  2. #22
    Found the spec
    Technical Specs:
    Measurements:
    Nominal Impedance: 3 ohms / minimum 1.77 ohms @ 310 Hz
    Sensitivity: 90 dB @ 1W @ 1m @ 315Hz
    Frequency Response: 20 Hz—33 kHz +/- 2 dB
    Minimum Amplification Power Recommended: 100 watts/channel
    Drivers:
    Main Tweeter: 1 inch (2.54 cm) Convergent Synergy (Mk5), Dome Material: Doped Silk Fabric
    Upper Mid-R anges: (2) 5 inch (12.70 cm) Cone Material: Paper Pulp Composite
    Lower Mid-Ranges (2) 7 inch (17.78 cm) Cone Material: Doped Paper Pulp
    Woofer: 10.5 inches (26.67 cm) Cone Material: Hard Paper Pulp
    Woofer: 12.5 inches (31.75 cm) Cone Material: Hard Paper Pulp
    Rear Firing Tweeter: 1 inch (2.54 cm) Dome Material: Doped Silk Fabric (Mk5)
    Rear Firing Mid-R ange: 5 inches (12.70 cm) Cone Material: Paper Pulp Composite
    Dimensions:
    Height: 84 ⅜ inches (214.29 cm) w/o spikes Width: 21 inches (53.34 cm)
    Depth: 37 ⅜ inches (94.87 cm)
    Enclosure Type MainTweeter (Sealed): Material: X-Material
    4” Main Mid Module (Bottom Vent): Material: X-Material with S-Material Baffle
    7” Main Mid Module (Bottom Vent): Material: X-Material with S-Material Baffle
    Woofer (Cross Load Firing Port ( XLF)): Material: X-Material
    Rear Firing Enclosure (Sealed): Material: X-Material with S-Material Baffle
    Gantry: Aerospace Aluminium with W-Material Module Interface
    Price and availability:
    Limited to 70 pairs US MSRP $685,000
    Nasty load but nothing a Krell or similar couldn't cope with. Quite a bit cheaper than a million dollar too. Although they ain't exactly giving them away.
    Only 90dB though, not the 99 I saw quoted elsewhere.
  3. #23
    I'm Deleted.
    Default OMG, Life Will Never Be The Same Again, I’ve Just Been Wammed!
    Refreshing to see that elaborate mains conditioning doesn't seem to be used, or cable lifters (even if they are using Transparent speaker cable with their special filter networks).
    I must admit I don't like the styling either. Sure there is an element of form being defined by function but still is some styling. The smaller WA designs are much better (visually) balanced for me.
    This pair appears to be called Dave.
    Account Deleted
  4. #24
    my little full range telefunkens are 3 ohm, but only need a trickle current .... come in a fair bit cheaper too 700k dollaridos is redic for 2 speakers tho... you could buy 2 lovely houses for that
    If you've got that much for speakers you probably already own several lovely houses. And a yacht.
  6. #26
    not really my point.... more if youve got that money for speakers then buy 2 lovely houses for deserving folk
    I'm matt.
    What impedance though?
    EDIT: - Looks like I'm too slow...
  8. #28
    I'm matt.
    Quote Originally Posted by Arkless Electronics View Post
    No matter how good, this is ultimately speaker drive units, probably bought in from the likes of Seas etc in a collection of boxes and £1000,000 for the full system is obscene IMHO....
    The upper mids are Scanspeak Illuminators - LINK
  9. #29
    I'm Josie.
    Why do they need to be so ugly?
    Tannoyista.com
    - Audio Equipment Reviews
    Facebook
  10. #30
    They're Wilson's Jo. Have you ever seen a pretty one?
    Now, if they were top of the range Avalons, things might be different.
