Hi Guys
As some of you are aware I am/have starting my tuner mega review. Very early days yet, but the combatants are now all in, and an interesting discovery has made about my choice of aerial, which makes things a wee bit more complicated than I thought.
General wisdom would suggest a nice big multi element aerial, mounted outside or in the loft is the ideal. These would all be of the 75 ohm type, using co-ax cable and an F Type or Belling Lee connector for hook up to the tuner. Well it seems that if you are using a late 60s or early to mid 70s tuner that might not be the best way.
Many of these tuners were actually designed to work just as well or better with a 300 Ohm cable aerial (the type we usually call Wet String). So if you use a tuner of this sort of vintage (with good sensitivity and selectivity), and live close to the transmitter, then I think you owe it to yourself to try it out. A 300 Ohm aerial will only cost you a few quid and the results may shock you.
This came to light after doing some research about a tuner in for test, a classic Sony. It like many of its early competitors prefer a 300 Ohm aerial, over a 75 Ohm. You can imagine my shock when the signal strength VU meter indicated the same levels of strength, as I was getting from the 5 element Yagi in the loft...and this from what I would view as a piece of rubbish wire. Oh yes sound quality...better too.
I will now be trying both types of aerials during this test period with all the early tuners....300 Ohm aerial now installed, in the downstairs listening room where the listening tests will be done.
So give it a try with your own tuner and let me know what you think of the results. This is not just about signal strength, but sound quality.
Regards D S D L
