Passive sub low bass cut off required?
Anyone know of a simple bass filter for a passive sub? Or a simple cheap sollution before the power amp?
I would like to be able to cut the low bass around 19Hz or 25Hz in a passive 100 liter sub, to protect the cone from over excursion and was wondering if anyone knew of a simple circuit or such I could build or buy?
I am also wondering if I should fit a passive low pass filter crossover? Though it will be utilised with sub out from an AV amp?
Really I want to roll of the low bass from around 25Hz or 19Hz and don't need anythng above 120Hz I guess? It's a simpe 100 litre ported enclosure with a 15" driver which will be port tuned to either 19Hz or 25Hz.
Cheers
- You may not post replies
- You may not edit your posts
Forum Rules
