Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: 'New' MM cartridge from Thomas Schick
    montesquieu Guest
    Default 'New' MM cartridge from Thomas Schick
    Having some fun lately with very low compliance MM/MI cartridges, notably the ancient Shure M3D, equally ancient B&O SP1 (I managed to locate a NOS tip for that), and not quite so ancient but still available Shure SC35C.
    Spotted that Thomas Schick has come up with a MM cartridge
    http://calamightysound.com/shop/cart...ick-cartridge/
    Bit of digging shows it to be a modified (quite how modified for the price difference isn't clear) one of these:
    In standard form it wants 5g which is quite a lot for an eliptical, 2.5g-4g for the 'modified'.
    Anyone know anything about these Tonar jobbies? The Shure SC35C I've been utterly astounded at but Tonar I've always assumed are bottom-feeders in cartridge-land.
    montesquieu Guest
    No comment from anyone?
    Sorry mate, never heard of the Tonar, so can't offer any advice. What did you make of the SC35C?
    if it was Al's then it might be diabolical ...I'll get me coat
    montesquieu Guest
    It's a cracker Marco. I had Bowie's Aladin Sane on this afternoon, the Miyajima and the Royal N of course allow far more insight into the recording, where you can hear exactly what's going on as the producer would have heard it, but my word, the SC35C was producing a fantastic thick, lively, enjoyable rock-n-roll wall of sound.
    What strikes me with both the SC35C and the Shure M3D is minimal distortion or compression at the peaks, something most cheaper cartridges do suffer from even with ideal setup and which usually the only cure is more $$$.
    I'm running both on headshells that give about 34g all up with the cartridge on, on high-mass arms - I suspect you wouldn't get quite this level of performance out of a lightweight or even a medium weight arm. I put the M3D a nose ahead of the SC35C - when I had it on last the wife came in from the other room and asked what was playing - this was some Renaissance lute duets, made it sound like Page vs Clapton (I kid you not) so punchy and lively and really captured the vibe of the improvisatory element. But there isn't much in it between the two ... the SC35C has a shade more detail, the M3D more balls.
    They aren't quite so good with Lieder and string quartets but hey you can't have everything. There's a time and a place for uber high end but sometimes you just want to boogie.
    Never tried that Tonar but it is a rebrand of an old Nagaoka design I believe.
    Tom, this is an old favourite on lenco heaven. There is a specific thread detailing many users who have tried it.
    PRE
    Tonar in the UK, used to be a supplier of replacement styli and budget cartridges. Nothing 'high end'.
    So it looks like it's been rebodied which means that a £50 cart will now cost at £1k
    PRE
    I'm gordan.
    I think opposite, it's stripped from plastic and mounted via adapter into a Schick graphite headshell which I think costs around 300e. I am not sure if you can buy separate (unless you were already a headshell customer), but Thomas' idea anyway was to use them together. I guess such a high damping headshell does a a part of the plastic job.
    Tom, btw, your Shure 35C, was it US or Mexican made, do you know? Are differences drastic?
    Gordan.
    Speakers: Oris Swing MkII
    Amps: Thomas Mayer 300b/ Hiraga La Maison de L'Audiophile 20
    Preamp: Silver AVC by eng. Ferenc Lazar
    Phono Preamp: Shishido LCR by Solaja Audio
    Decks: Garrard 301 Martin Bastin reworked/plinthed with Fidelity Research FR64fx
    Garrard 401 in eng Ferenc Lazar solid wenge plinth with SME 3012/2
    Cartridges: SPU Spirit/ Koetsu Black revisited by eng. Salai/ Miyajima Shilabe
    Step Up Transformers: Tango MCT 999/ Ortofon T-5000/ Lumiere SUT
    Digital: Shigaclone by eng. Ferenc Lazar with Lampizator Amber II
    Wires: of sufficient length
