Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Removing push-in spring clips and replacing with binding posts (Speakers)
    I'm Richie.
    Quote Originally Posted by spendorman View Post
    Well, I'm not really a "Tannoy man"
    Username checks out...
    I'm Alex.
    I think the Maplin binding posts that I bought are much like the Mitchell ones.
    Perhaps use a vacuum cleaner to remove any debris inside if there is any.
    I found the HPD 315's a bit heavy when removing them, just be a bit careful not to drop them.
    Spendorman
    I'm Alex.
    Quote Originally Posted by martian sunrise View Post
    I'm Radfordman on another forum!
    Spendorman
    I'm walpurgis on another forum or two.
    I'm Alex.
    One thing I forgot, the drive unit is connected by means of a 4 pin plug whose contacts can get dirty / corroded, causing intermittent connection.
    I put a little Servisol contact cleaner/ lubricant on the pins, inserted the plug and took it out a few times, wiped the pins with a cloth, then a little more Servisol, no further problems.
    There may be better ways to cure this, but this way worked for me. High quality plugs and sockets (probably better than the originals) are available.
    http://www.ebay.co.uk/itm/Servisol-S...-/281978460634
    Spendorman
    I'm Richie.
    thanks
    I'm Alex.
    Spendorman
