As my DAC/Pre has balanced outputs and the amps on my horizon have balanced inputs I thought I'd run my system fully balanced.
Anyone used balanced versus single ended and how much better (if at all) were the results?
Cheers!
Cheers!
Ben Duncan mains conditioner
Samsung QE75Q90T 75" QLED TV
Atacama SE24 stands
By all accounts it's worth doing. Usual answer along the lines of "try both and see which you prefer" applies I think.
I've used balanced before but on the kit I had it was the only thing fitted, so a comparison was impossible.
Cheers,
Mike.
Shian7
Kudakutemo
kudakutemo
ari mizu-no tsuki
Though it be be broken -
the moon on the water.
- Choshu.
I think I'll get some cheap cables to start with and if they are clearly better than single ended I'll plump for some decent ones. They're damn pricey though, maybe I'll talk to Frank - not the drugs hotline though.
Atacama SE24 stands
Rob,
How many and what length would you need?
What connectors on the end?..... Most leads have a male at one end and a female at the other. Others can have both ends female, or both ends male.
I may have some still lurking around somewhere. Or I could always knock some up.
Cheers,
Mike.
Shian7
Kudakutemo
kudakutemo
ari mizu-no tsuki
- Choshu.
Well, I need male to female (2 of), as for length it doesn't matter; if they're short I'll put the DAC/Pre near the amps, if they're long I'll put the amps near the speakers. Anything you've got (or could make) would be very helpful mate, obviously I can furnish you with some beer tokens.
Atacama SE24 stands
Hehe... not long now until those black evil beasties will be gracing your rack.
Can you feel the excitement? Have you warned your neighbours?
I can certainly feel the excitement, I've had to start wearing bigger trousers.
My neighbours will not know any difference as I'm careful with my listening levels - for the time being anyway.
Atacama SE24 stands
Shian7
Kudakutemo
kudakutemo
ari mizu-no tsuki
- Choshu.
Cheers Mike.
Sorry, yes, XLR both ends - I forgot that balanced could be DIN. I'd prefer to have the amps nears the speakers and the DAC/Pre near the source if possible, however whichever is less likely to pick up interference is the method I'd go with.
What would you suggest, long interconnects or long speaker cable? I'm only talking 5 metres for either.
Marco, on the subject I'm assuming that the EA-1s have binding posts and not just banana sockets, would I be correct? The website really is painfully lacking in information.
Atacama SE24 stands
Okeydokey.......
Lemme see whats kicking about.
I'll be be back to yah........
Shian7
Kudakutemo
kudakutemo
ari mizu-no tsuki
- Choshu.
