Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: 24bit 192khz upsampling tube dac
    I'm Duncan.
    Default 24bit 192khz upsampling tube dac
    latest project, this time in 5mm clear acrylic with white oak sides.
    12mm clear/transparent blue front panel.
    Digital receiver – CS8416
    Digital converter – CS4398
    Up sampling chip – CS8421
    USB IC - PCM2902
    Digital input – 1x coaxial, 1x optical, 1xUSB
    VVT Transformer, Toroidal transforme
    Tube rectification with Ez81
    Obligato Film Caps
    AmpOhm Paper in oil coupling caps
    Kiwame resistors through out
    6N3P-DR military spec double triodes
    Oh mammy, daddy... That's wet yer panties stuff, mate - looks seriously lush!
    So....the key question: how does it compare to your copper DAC?
    Serious, beautiful bling.
    I think I'm in lurve . . .
    I'm Nobody.
    Duncan:
    who do you get to make the Acrylic to size, everyone i've used always make a cock up of the edge polishing?
    I'm Duncan.
    i do all my cases myself, as you have total control
    I'm Nobody.
    Quote Originally Posted by tubehunter View Post
    How do you flawlessly diamond polish the edges then?
    I'm Duncan.
    Start of with cutting to size on the Bandsaw then two grades of files.
    Next 240 then 400 then 1200 grades wet & dry and finally Basso gets you there.
    Time consuming but satisfying when finished.
    Just a brief description; I'm not looking for an 'epistle'
    I'm Duncan.
    interesting
    give it a chance, it was only born 30 minutes ago!
    I'm inthescottishmafia.
    That looks the business Duncan.Very nice!
