I don't understand the drama, of course they will sound different. If all CD transports or CD players with digital outputs sounded the same then there would only be need for one manufacturer and a £100 player would sound the same as a £5000 player.
Every part of a Hi Fi chain can affect the SQ, even down to fuses and binding posts.
Best not. But have to say I thought the same as you re CD transports until I tried it for myself. It isn't night and day difference but is more than one can wilfully put down to imagination. Although I accept a lot of transports will be indistinguishable from one another.
I'm Al.
Another thing - is the perceived audio level you hear from the speakers exactly the same when you switch transports? Have you measured it with a sound meter?
A slight difference in sound levels easily fools the brains perception of audio quality/detail.
I'm charles.
Arkless Electronics - I have been listening to hi-fi for over 40 years and whilst I'm sceptical about a lot of things, I trust my ears - there is a demonstrable difference between these two units which I can discern on a blind AB test - it's not snake oil and it's not imagination and I'm not a flat earther - I'm just a normal guy who loves music and hi-fi in equal amounts - not into cable differences, Russ Andrews etc etc. Just sayin'
I'm charles.
Sound levels are the same - there is a perceived darkness and richness with the Denon and an open, lighter balance to the sound with the Sony - I like both of them!
