Hi Al
Connect source to input at rear of A77
On the selector switches select Aux on both channels
Depress the red record switches for both channels and the red lights should come on in the VU meters
Bring the tape in contact with the heads using the edit lever near the pinch roller, if you are playing music into the recorder the meters should move so you can set your record levels with the pots in the selector switches
Press record and Play simultaneously to start recording
conect a lead from the outputs of the recorder to your pre amp to monitor the recording or playback
Alan
