Part XIX - A few thoughts on the system.
I've been listening to the system now for a few days and I've begun to understand it's strengths and weaknesses. The who system has just worked so well together that I'm having a blast listening to stuff, sure my other systems can do things better but this little system does fun in spades. Most people ask how the cabling sounds. Well, bass is abundant, it's not the most taut but rather tuneful. Vocals can sound very very good especially close mic'd MONO recordings, plenty of timbre to the vocal chords of most performers. The TT2 has been the biggest surprise, it really is a deck for all occasions and does every genre very well indeed. I've had everything on the deck over the last couple of days, classical, prog, heavy metal, jazz, female vocals, electronica, folk etc, all sound very good.
The Alphason + 2M Black have matched exceptionally well. The "black" cartridges have a house sound that is very analytical, bass abundant, PRaT, but not so good with surface noise. The 2MB is very critical when beening loaded and likes to see very specific levels of capacitance. My EAR 834P clone has the ability to use loading plugs, so far, I've used nothing with the 2MB and got the best results. A slightly darker noise floor but just with a little hiss, not bad for the 834P which is known to hum like a bugger (mine silent)!! I did make a tonearm cable out of Duelund cable for the Alphason, this replace a Nordost TYR + eichmann silver bullet cable, and I can honestly say that it not only equals it's performance but beats it! My soundstage is quite holographic and it's quite easy discern width and depth, yes each band member has their own space in the soundstage. I will at some point go into more depth about how things sound with the cabling but not tonight, it's been a long day. I will just end by saying that it's a very addicitive and emotionally captivating system.
Stay tuned...
