Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 60
Thread: Floorstanders - 2 way or 3 way ?
    There has been the odd big vintage multi way JBL that I've liked. The Avant Garde Trio with the big bass unit sounds incredibly good (well, it actually just sounds incredible). The old Spendor S100 was very sweet too.
    I like the Edingdales. they are I think 3 mid/bass drivers and tweeter, but 2 way. Sound superb with most setups, although I think room needs to be decent sized if your using any power. A bit like mine really,
    I quite like a 2 way with passive bass, as in my Cara's, but I'm mostly into 1 way. 3 way does make xover points more complicated, and very important to get right.
    But using a driver just for the mid band means you can put the crossovers at less sensitive positions in the frequency range. Hearing is most sensitive 1-3 KHz which is where your two way usually crosses over. A Tannoy DC is in practice a three-way and the crossover is below 1Khz.
    I know mine are quite sweet, at there price point martin. Not a huge bass line but I like that. Ive not used them for some time, but dont feel I want to sell, as they are the best set of their type Ive had, at anywhere near pricepoint.
    danilo Guest
    Late Night? ... perhaps.
    The combination of the horn throat and the inner circumference of the cone effectively makes a mid-range driver. You'd need someone like Paul RFC to explain the exact technicalities.
    3 divided by 2 is 1.5 and that's not right either!
    I'm Andre.
    I am a 3 way fan. But resently had a listen to the Klipsch Reference Premiere RP-280F which is a 2 way construction, and they sounded incredible to my ears. 1 horn and 2 x 8" bass/midrange.
    Not many hi-fi manufacturers use such large woofers to also play the midrange as it may cause phase problems and a very narrow scatter characteristic in the upper midrange area. Klipsch solved this by sliding the crossover frequency between these and their tweeters down to a low 1.750 Hz.
    Their sound aside; the cabinets are very deep, and need a good distance from the wall - so they would take up to much room and be to dominant in my livingroom.
    Marantz HD-DAC1 -> Pro-Ject Pre Box S2 Analogue -> Hitachi HMA-8500 Mk II -> JBL Balboa 30
    I favour 3 or more way speakers myself. Has to be done well but when done well its the mutts nuts.
    Let the tweeter do the treble, the mid do the mid and woofer do the bass.
