Results 1 to 10 of 17
Thread: JBL TL260 midrange problem
    I'm Andre.
    Default JBL TL260 midrange problem
    Maybe this thread should be in "Technical", but that look more like an information section rather than a place for a technical question.
    Anyway, bought a set of mint looking JBL TL260 limited edition (60th anniversary) speakers. The only problem is that the midrange speaker in one of them is not sounding like it should. Can feel no vibration from it when holding a finger on the membrane, even though it has sound coming from it, but very little. On the other cabinet the midrange membrane vibrate well and sound good.
    So the first thing I did was changing the midrange speakers over from one cabinet to the other. The result is that "the bad speaker" comes to life like normal in the other cabinet. So the speaker itself is no the problem.
    My thoughts now is that the problem is the crossover. The soldering looks good on it, so I am thinking a bad capacitor is to blame. The yellow and yellow/black cable is to the midrange. There is a 100v 14uF capacitor in connection to it there on the board.
    My crappy multimeter can't measure capacitance, but if it could I guess I will need to desolder the cap to get it out of the circuit to check if it is good or not? These are JBL's own caps - called "Sounder", but I guess any correct spec hifi grade cap would do as a replacement? Or would it be better to put a quality Nichicon or Elna cap in there?
    Marantz HD-DAC1 -> Hitachi HMA-8500 Mk II -> JBL TL260 limited edition
    by the bad speaker, I take it you mean the bad driver? Yes you will need to desolder the caps to check. Good quality replacements are best. also check the wiring is same on both.
    Grant .... ؠ
    OPPO BDP-103D - PANASONIC UB450 - IFI PURIFIER 2/PATHOS CLASSIC REMIX & HIDAC AMPLIFIER - LEAF HD BLUETOOTH - NURAPHONE' HEADPHONES - 2*ZBOOK'- ROON - MULTI HDD'S - DIGIONE RPI3 - EDINGDALE MK1 SPEAKERS - CABLE INC SUPRA, FISUAL, MOGAMI,
    **Ive studied deeply in the philosophies and religions, but cheerfulness kept breaking through**
    "An old man sleeps with his conscience at night, while young kids sleep with their dreams"
    "Justice is sinking to the bottom of the sea, And it feels like I'm living in the wasteland of the free"
    It was the weakest practical joke since Cardinal Wolsey got his nob out at Hampton Court and stood at the end of the passage pretending to be a door!
    I like my whisky old and my women young. Errol Flynn
    I'm betting it's a bad joint of one kind or another. I see there are crimped spades in use, horrid things. They can be problematic. Personally, I'd replace them all with solder on types. Some folks may even remove them altogether and solder all joints. Can you not check continuity with the meter? If it is a bad joint/spade, you should find it.
    The word is 'valves' in this country, not tubes. Tubes are what Smarties come in!
    I'm Andre.
    Yes, bad driver I meant there.
    Ok, will take the crossover to a mate and check things out with a meter. Thanks.
    I'm Andre.
    Ok, thanks.
    I'm matt.
    Can you not play some music or sound through the speaker and just wiggle the connections to the crossover board and driver? If that doesn't work try wiggling the components on the crossover board.
    I'm Andre.
    Had the crossover checked. Nothing wrong with it. So I changed the crossovers over between cabinets. It didn't fix anything. But confirmed the crossover is ok.
    This led me thinking "walpurgis" was correct in his answer above; a bad spade. Put on new spades both for crossover and driver end= SAME!
    I changed the entire cable for the midrange= SAME! At this point I was so shocked that I AGAIN changed the midrange drivers over= SAME!
    This is maybe the strangest thing I have ever seen/heard. No matter what crossover, cables, spades or driver I put inside the right cabinet, it vibrates less than the midrange in the left cabinet.
    I think I'll just get
    Presumably the open back midrange driver is in its own inner enclosure. Is there anything loose inside? Another possibilty and quite a common one is a wire or damping material touching the back of the cone.
    If it isn't the speaker is it anything upstream? Have you tried swapping the speaker cables around to check? I've been there before, chasing the fault in one piece of equipment when the problem was elsewhere. Weeks of grief.
    *Audiolab 6000CDT* SoncozSGD1 * Krell KSA100 mkII * JM Lab Electra 926 *
    'You fool! To think that your ape-brain could contain the full knowledge of the Krell!'
    What Marco said.
