Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Cupping Hands Behind Ears
    I'm Shane.
    Default Cupping Hands Behind Ears
    Have some of you members on here tried this? Whilst sitting in front of your Hi-Fi with music playing. You certainly hear more upfront detail, and the imaging improves. The music just instantly becomes more tight and focused.
    But, after listening this way for a while, especially with certain music. The sound then now becomes a bit tiring etc. It's a bit like, if there is an EQ with the treble turned up a bit more....crap analogy, but it's hard for me to explain.
    Anyway remove your hands away, and the sound now becomes more flat/dull sounding. Then after listening in ''normal mode'' for a few minutes you just couldn't give a damn anymore. The brain/ears is simply adjusting to the older sound.
    I've experienced this with many systems, and outside noise as well.
    It is indeed very true though. We all hear differently!
    S.
    I'm Simon.
    Just recently I've found that sticking my fingers in my ears whilst simultaneously putting my hands over my eyes works best.
    Hi-fi is a great hobby. You can put a record on and turn off for 40 minutes, then turn over to the B side.
    Rinse & repeat.
    Do you cup your ears when you attend concerts? Do you cup your ears when talking to friends? I don't, so why should I want to do so when listening to my system.
    I'm gone.
    It works, though, just as Shane describes - I've tried this and pondered it many times.
    Unlike Shane I've never tried perservering with it.
    I'm gone.
    ... decades ago someone sold accessory leather ear flaps/extensions to do the job.
    Can't find a pic of them, though.
    I'm Andr'e.
    Just sitting down and listening to music without pissing about is more normal, ok I have been know to pick my snout at times but the music still sounds the same
    I'm John.
    It's because of your elbows.
    danilo Guest
    Likely Why God gave us hearing aids.
    It improves amplification especially around the 1/3 khz areas apparently where up to 10db worth of improvements can be found depending on how you do it
    I'm Marc.
    Get yerself a pair of these:
    There's also a 'low WAF' version:
