Page 12 of 14 FirstFirst ... 21011121314 LastLast
Results 111 to 120 of 137
Thread: Garage Conversion
  1. #111
    You've done a great job, enjoy the fruits of your labours.
  2. #112
    I'm Adrian.
    Quote Originally Posted by glenann View Post
    It’s ok actually. Better than I thought it would be. It needs work though. There is still pretty bad flutter echo and I need to spend time placing the speakers correctly. I plonked them using the Cardas calculator and haven’t bothered to move then since. Bass needs a little more body for me, but I’ll wait until I’ve built the bass traps. Then I can build the first reflection point absorbers. I’ll probably add a skyline diffuser at the back to complete the treatment if I can be bothered!
    You might want to consider hanging a triangular sail up in ceiling, an often overlooked large reflective flat expanse, I threatened this in our lounge and even though I gave a list of aesthetic and artistic reasons SWMBO firmly put her foot down and waggled her finger and head at me. I think I was pushing my luck a bit.
  3. #113
    Looks a very nice 'den'. Like the rack.
    The thought did cross my mind, will any future owner spend ages converting it back into a garage?
  4. #114
    As Glen already has some acoustic insulation my offer is now open to other members. Namely, an unopened pack of Rockwell acoustic insulation. The pack contains 4 blocks, each 100mm thick and measuring 1200mm x 600mm. The 100mm version is the sweet spot for acoustic panels, and 1200mm x 600 mm a good sized acoustic panel.
    Free to anyone who can collect from Warsop in North Notts (on the edge of Sherwood Forest).
  5. #115
    I'm Glen.
    So after a busy afternoon.. proper bass traps!
  6. #116
    very tidy.
  7. #117
    Out of curiosity, what materials did you use to make the bass traps and has it made much difference to the acoustics?
  8. #118
    I'm Glen.
    I actually used three pieces of arris rail, I think they call it, as it's cut in a triangle shape. With a board top and bottom. Then some RWA45 insulation I had spare. Wrapped in burlap/Hessian.
    It's certainly tamed any tendency to boom. The bass seems fully controlled. With some test tracks I don't feel the need to turn it down at all, which is a good thing I suppose.
  9. #119
    I'm Adrian.
    Very nice job Glen, looks very professional.
  10. #120
    I'm Glen.
    At the insistence (yeah right!) Of my daughter, I 'had' to buy a TV for the room. A nice 65" Panasonic OLED fit the bill nicely. I have to say the picture quality from 4k and Standard Blu-Ray is astonishing.
