Page 1 of 14 12311 ... LastLast
Results 1 to 10 of 137
Thread: Garage Conversion
    I'm Glen.
    Default Garage Conversion
    As per the title, I have an opportunity to build a room within a room in my brick built garage. As I said the walls are single brick sat on a concrete pad. I'm trying to keep it as simple as possible, so it'll be a floating floor and then 3x2 stud wall with rock wool insulation throughout. I'm getting a joiner to do the stud work for me.
    So there are two points really, first does anyone have any useful tips before I start? And secondly and probably more importantly, what size should I make it? Two of the dimensions are fixed. The width will be 9ft, maybe a couple of inches more. The height will be about 7ft, possible reducing toward the back of the garage. So what length should I make it? I can go to about 16ft. Should I make it as long as I can, or does the golden ratio come into effect? I have no clue about these things, so any input would be most welcome. I use Harbeth P3ESR's at the moment.
    Thanks for any input...
    I'm Scott.
    Golden ratio (or any other acoustic ratio for that matter) certainly doesn't hurt. Generally, being of the caveman persuasion I'd suggest 'as large as practical' and if it's golden or another acoustic ratio then so much the better (although if you can avoid a direct multiple, well & good). Thing is, the dimensions of the room are only one factor and usually aren't the dominant one since construction materials are quite likely to have a larger effect and there are always things you can do to disperse or damp things out as required. Like speaker cabinets, it's generally better to have them over-sized. If you've got too much of something, there are things you can do to get rid of what you don't need. It's generally harder to increase what doesn't exist in the first place.
    A floating floor isn't the beau ideal, ditto for stud-walls, but then, most houses are built like that, so you've plenty of company. I suspect it'll leach out some bass energy though. If possible, you might want to look at a couple of concrete plinths coming up through the floating floor to put the speakers on. Granted that does tie you to specific positions; you could use George Cardas's guidelines http://www.cardas.com/room_setup_main.php which may help provide a general guide. Not a panacea, but they should serve as a starting point. That's my quick & dirty take anyway. Of course, it's all very easy for us to make suggestions since it's not our money. Hence the reason I suggest doing what you can to hedge your bets rather than necessarily following any fixed / proscriptive formula.
    Some of the soundproofing plasterboard might help a bit with the bass leaching.. just hope your strong coz they weigh a ton lol
    Grant .... ؠ
    OPPO BDP-103D - JBE SERIES 3/B&O SP1/PROJECT PHONOBOX DS2 USB - QUAD VENA 2 - IFI PURIFIER 2/TWIN PRO MONOBLOCK POWER AMPLIFIERS - LEAF HD BLUETOOTH - OPPO PM-3 PLANAR, SONY H900 & NURAPHONE HEADPHONES - ZBOOK/ IFI SILENCER/WIN10 PRO/AUDIRVANA & JRIVER - SMSL M6 DAC & IFI SILENCER - RPI 3+, DIGIONE HAT/VOLUMIO2 - EDINGDALE MK1 SPEAKERS - CABLE INC CHORD, MOGAMI, SUPRA & WIREWORLD
    **Men are not punished for their sins, but by them**Don't be such a big girl's blouse!**
    RIP Terry... "We use only the finest baby frogs, dew picked and flown from Iraq, cleansed in finest quality spring water, lightly killed, and then sealed in a succulent Swiss quintuple smooth treble cream milk chocolate envelope and lovingly frosted with glucose."
    I'm Glen.
    Thank you Scott, that looks like a good place to start at least. Thanks for taking the time to reply...
    Cheers buddy
    I'm Glen.
    That's a good point too, thank you
    I'm Rob.
    I did what you are intending to do about 7 years ago. I have a large double garage and built a room in half of it. As it was single skin I (yes I did all the work) put Synthaprufe on the external walls (lovely job!) then battened it all. A carpenter friend sourced all the materials for me which included fibreglass insulation that he said was not only for heat insulation, but had acoustic deadening properties as well, Cellotex sheets and acoustic grade plasterboard (a 1200x2400 sheet weighed about 80lbs) Two of us tried to put the plasterboard sheets up for the ceiling.......even with supports we failed and ended up with one "holed" board. it took three of us to do the ceiling.
    My room is about 9.5ft x 19ft. Not an ideal shape but it is as it is. I get an LF boom prob around 200Hz, but with clever tuning it is not too much of a problem. What it does give me is :-
    A virtually sound-proofed room
    Somewhere I can listen with no hassle
    It is a shit-hole most of the time
    Mine is a concrete floor. I painted it, and put 2 layers of underfelt and an old carpet that we just renewed in our bedroom and it is very good.
    https://youtu.be/ZCBe7-6rw4M
    Quote Originally Posted by Puffin View Post
    One man's shit hole is another man's paradise .
    Aye my son in law sometimes uses it.. says its heavy, even for him, and he is a big lad.. as you say a 2 man job just getting it in position sometimes.
    Grant .... ؠ
    I'm brian.
    Interesting thread.
    Ive been thinking about trying to do something similar.
    With no prior knowledge or experience, I thought of building a breeze block room, straight off the concrete floor.
    I would want it as sound proof as possible but my worries were noise escaping through the roof of this new room and through the door into it.
    Any thoughts on how to overcome the noise "bleed" problem.
    I'm Marc.
    What are your priorities? Sound proof or 'nice' sounding? (you can (sort of) do both but it's exceptionally costly and difficult for a space that size).
    There are a whole bunch of calculators online for working out what the problems are going to be based on the dimensions you have, I'm afraid you're unlikely to have sufficient adjustable space to make a significant difference to the modes/nodes that will occur with those dimensions - you need something at least as long as the lowest frequency, a 20Hz wave is something like 13m long.
    Anyway try searching for room mode calculators, theres one here: http://amroc.andymel.eu/
    Also worth looking at the john sayers studio forum, lots of thoughts, plans and discussion around the various issues of soundproofing and acoustic treatment. http://www.johnlsayers.com/phpBB2/index.php
    I converted my garage in to my studio room, I set in a very large gap between the exterior and interior walls - enough to put celotex in for thermal regs and a bunch of super dense rockwool for the acoustics. My initial gut reaction tip on what you've said so far is don't float the floor (unless you have a very clever plan to isolate it from the walls.
