http://www.ebay.com/itm/Assembled-LM...8AAOSw7aBVCmdK
Here's a slightly different take with OPA2604 .
The price is so good , it's probably worth checking out .
I've tried various LJM kits , with very good results , and every time from this seller :
http://www.ebay.com/itm/DIY-KIT-LJM-...item2c92433554
I've tried the following :
LJM L25D ( IR class D ) - very close to IR reference circuit , amazing performance with 400VA torroidal + dual rail supply ( 6x 10 000 uF Nichicon 80V ) ; or with 2x Abletech 53-0-53 SMPS ( one smps on 2x modules blew smps )
LJM L20 ( Class AB ) - excellent with 400VA torroidal + dual rail supply
LJM L25 ( Class AB with onboard opamp pre ) - excellent with 400VA torroidal + dual rail supply
I see that the seller only sells the L15D Pro and L20D Class D's now . I'd like to get these in future too . I can highly recommend the linear dual-rail PSU option . I built my own , but he sells those too , probably cheaper than building your own . SQ with linear supply sounds effortless and is completely neutral . Simply amazing .
