Page 98 of 171 FirstFirst ... 488896979899100108148 ... LastLast
Results 971 to 980 of 1701
Thread: Macca's Lash Up 2: Lash Harder
  1. #971
    I'm Adam.
    Out of interest, did you, Macca, or Al get your Philips Black turnip preamps sorted out?
  2. #972
    Quote Originally Posted by Beobloke View Post
    I haven't. Mine is way back in the queue of 'things that need fixing.' Lockdown doesn't help.
  3. #973
    I'm Allen.
    Good reminder I will see if I can find my one
  4. #974
    I'm Allen.
    OK , now located , Its a Philips 270 pre , However it only has tape Phono and tuner
    No Aux or CD
    Can I run a CD through the tuner input ??
    HELP
  5. #975
    Maye they should re name it a Marco , He can be a bit of a monkey
    Aye, and not a good bit. The bit you see them playing with when you take your kiddies to the zoo
  6. #976
    No Aux or CD
    HELP
    As far as I know, they'll all be "line level", and interchangeable.
  7. #977
    No Aux or CD
    HELP
    It's from 1979 so pre-dates the introduction of CD. You can use the tuner input it's exactly the same.
    In other news I now have the Sancoz DAC up and running. Not had long enough to give it a proper evaluation yet but it does sound very clean and clear.
  8. #978
    I'm Allen.
    OK later today I will give it a try
  9. #979
    I'm Allen.
    Just tried the 270 pre and yes it does work , along with the Sony CD player and my big valve amp , sounds terible
    Will see if I can find the power amp that goes with the 270 pre
  10. #980
    It will sound terrible (flat and 'sat on') because a typical tuner input has a sensitivity of 100mV, whereas a CDP can put out as much as 2V.
    A friend of mine used to say how bad CDs sounded. It wasn't till I heard his setup (a Cambridge CDP, running into the radio input of a Harrison S200 integrated amp) did I understand what he meant. His amp was being overloaded by the CDP. A change of amp to one with a proper CD input sorted the problem.
