"Bright angle" - would you mind explaining the difference as I can't see it .
I've typed this now... but I guess I can also look it up myself.
I'm Sam.
I'm Sam.
They do look great by the way.
My System
John Wood KT88 Amp.
Paradise Phono Stage
Sony TTS-8000 Turntable.
PMAT-1010 MK6 Tonearm.
Ortofon Cadenza Bronze
Sony X555ES Cd Player
Yamaha NS1000m Speakers
Looking good, Jamie! So are you using the two of them together as a kind of 'Phase 2' arrangement? How do the MKIIs compare, sonically, with the previous versions?
thanks,yes that's how im using them.
they sound much better than the first pair i made,wrong choice of angle iron there,they were too big and no flex.the choice and size of the angle iron is the key,also using Formica on mdf(like the real ones). they is a distinct tone with these when tapped.
my only reservation is maybe the spikes on phase 2 should be reduced in size?
My System
John Wood KT88 Amp.
Yup, both sets of lower spikes could be considerably shorter, especially the top pair. However, you've got the 'stubbies' spot on
I'm Dean.
I would like to get custom frame and sound base made in the mana style. I have a couple already with shelf spacing of 160mm These are not wide. enough
Looking at 175-200 mm gap between glass and next shelf.
Can you offer any advice.
Marco,
I seem to have read somewhere that your had some made clones made in stainless steel, what other improvements did you make?
If I am having to pay to have one made it would be great to understand what can be done.
Jamie
those stands you made looked pretty good to me.
Dean
Hi Dean,
No improvements other than having the frames and spikes made in non-magnetic stainless steel, which was a *BIG* improvement! Otherwise, all else remained the same. If I can help any further, let me know
I'm Dean.
Hi Marco,
thanks for the info.
Did you go for the same size 20x20,3mm in Stainless? Who supplied the SS screws, would I be able to order from them?
Next I have to find a local metal fabricator who works in Stainless steel.
I'll let you know how I get on.
Cheers
Dean
dont forget to ask who makes them to use either 'bright' stainless steel or 'bright' mild steel,its what mana used,the only difference is the edges are squared off instead of rounded off.
My System
John Wood KT88 Amp.
