Originally Posted by
Themis
Yes, Steve, this clause applies if the "product" you bought is computer software only.
Imho, You should contact the seller and see if they accept. They often do, this clause is for abuse use (copying, then returning), usually. If it's your first return, and you're a regular customer, there should be no problems.
Hi Dimitri.
This isn't just a piece of software, it's a hardware accelerator USB 'dongle' that has software to go with it. More importantly, the software ONLY works if you've got the USB widget, so there would be no point in copying it anyway.
I don't even know if there will be a problem, but it's not a company I have used before. That said, their price, delivery and service has been good so far, so I'm hoping it will all be fine.
Steve aka 'Twelvebears' (it's a long story)
System: Technics 1210 Mk5, Jelco 750 arm, AT33EV via MF X-LP2 Phono Stage, Oyaide mat and record clamp. SB Touch via Marantz PM-11S1 amp and Wilson Benesch A.C.T. speakers. Mark Grant cables and PS Audio Power Plant Premier mains regenerator.
(\__/)
(")_(")
