Results 1 to 10 of 20
Thread: simplify media
    Default simplify media
    one for the geeks this i think, what's gone wrong? i've downloaded this app and set it up on my mac mini/iphone no probs, except when i goto preferences>music and select my external hdd i get a 'no music available' message, if i select itunes library and playlists i can access just 17 tracks of 60 odd gig thats on the ext hdd, can anyone help?
    my itunes works fine, if i use remote on the iphone all my music is available, as it is via the ibook, go connect to server, mac mini, screen share options.
    it seems my ext hdd isn't in my 'music' folder, help.
    cheers
    steve
    p.s,
    i just downloaded a song from itunes and my available tunes has jumped up to 18, don't know if that helps but there you go, make of it what you will.
    cheers
    steve
    update,
    i may have found the problem, in simplify media>preferences>my music folder>add individual folders>ext hdd> if i now select any album and click ok, i get the message 'there are no music files in the folders selected'
    to me this points to file ext problem?
    steve
    I'm Nick.
    Hi Steve - hope you can get to the bottom of this. I have a Mac, but I've not tried Simplify, so can't offer much help. Hopefully someone will pop by who can shed some light on things. You may well be on the right track though. Interesting that iTunes purchased content appears, but your other stuff doesn't. Was the track you purchased iTunes Plus or bog-standard DRM'd stuff?
    Are you running the latest version of iTunes? Have you tried ripping something off one of your own discs since installing Simplify, and does that appear OK, like the track you downloaded from the Store?
    Good luck getting things sorted.
    Nick
    My system...
    Follow AOS on Twitter: @AoS_Forum
    Default simplify... a note of caution
    ok so i think i've cracked it, the 18 files that are available are all m4a, i.e. apple lossless, the 60 gig that's gone missing are all aif. so it seems simplify doesn't recognise aif, luckily i have a large lossless library on the ibook so i wiped the ext hdd, and copied the itunes folder from the ibook onto it. i'm hoping i'll have loads of tunes available for those who wish to join me.
    i'll let you know how it goes.
    steve
    p.s before you ask yes i backed up the ext hdd to another ext hdd before wiping.
    Default simplify won't recognise aif files
    well the title say's it all really doesn't it? i'm now sharing 'quite a large no of files' simplify informs me, about 300 albums for your perusal.
    if your planning on using simplify, go lossloss m4a.
    cheers
    steve
    I'm Dan.
    alright steve, if you want to have a browse through my stuff, my username is pogoyen, and you're welcome to add me. it's left online most of the day
    Default simplify
    anybody else bothering? invite me or give me your name and i'll invite you.
    thanks
    steve
    I'm Gary.
    Hi Steve,
    my User name is Gazjam...
    35k tracks for your perusal!
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
    I'm Lee.
    Mine is lrwebb
    Just a thought, all simplify users could add their username to their sig, no?
    Lee
    Independent Apple tech support guy at Macnology
    Gear: iMac > ALAC > Airport Express > Beresford Caiman DAC > Mark Grant IC > Audiolab 8000S > Chord Rumour Speaker Cable > Dynaudio Audience 42 Speakers > Grado SR80 Headphones
    Vinyl: 90's Rega Planar 2, RB250, Bias Cart, Rega Fono Mini
    Last.fm
