Having just posted how good a match my new NAD C270 power amp was to my C370 - I now find that my headphone socket no longer works!!!!!! (on the C370) Is this because the power amp is connected???? Is there a way round it??
I'm Graham.
"An intelligent man is sometimes forced to be drunk to spend time with his fools" Ernest Hemingway
Set-Up (So Far) Garrard 401 with Rega 300 arm & Black 2M, Longdog Audio twin valve dual input phono, Denon DVD 2500 Transport all through Creek Destiny Mk1 integrated amp into Rega RS3 Floor standers
Never had any headphones so can't help but thats a strange one
I'm Graham.
The headphone output may well be taken from further up the chain and as your outputting from the pre section it may not work. Unplugging the amp from the power amp will prove this theory.
i suspect this must be the case with all pre/power combos the power output is now from the C270.
I'm Graham.
After a quick read of the manual and it stating that they are both identical in gain and that I can connect to the pre out 2 and leave the pre out shunt in place - I'll try this tomorrow to see if that changes anything
I'm Graham.
Or on another track......If I bi-amped with one amp per speaker would that work or do I need to have 4 posts on my speakers??
What happens if you switch off the power amp. Do the headphones work then?
I'm Richard.
