I'm gary.
I'm Sam.
My view is that if you're going to replace the drivers with ones which don't try to be direct replacements, then the speaker kind of becomes a little pointless - better to build a new cabinet which is designed for the new drivers.
Are these the ones which use the same dome mid-range as Celestion 66s?
I'm gary.
Yes. that is a Celestion midrange unit. MD500 model if I recall. Along with the Celestion HF2000 tweeter. Bass driver I believe is a Philips, don't recall the model number.
These speakers in my opinion (as I've said) are probably best kept as near standard as possible. They are a bit of a 'Classic' and fairly rare. Any cosmetic problems should not be too hard to address.
You will probably spend more on new surrounds for the KEF ABR units (if you can still find any), than you'd spend on second hand replacements. If you buy later replacement units, you won't have rotting foam surrounds to worry about, as they use synthetic rubber instead, which lasts. And, fitting new surrounds to these is a bugger of a job. I've done a pair.
I'm gary.
I'm Sam.
Perhaps time to hit the phone or email - internet searching only gets so far (results are based on links between sites, nothing more) whilst someone's personal knowledge can cut through that.
Indeed maybe try posting a few wanted ads too, you never know your luck, a pity Geoff doesn't have these anymore http://theartofsound.net/forum/showt...onal-condition
Darren.
Listening Room.UNDER CONSTRUCTIONTurn Table. Garrard 401, Reso Mat, 2 Tier Slate Plinth, DIY Hadcock GH242, Nick G modded Lentek, Denon DL-103.
Pre Amp. Croft Super Micro2. Power Amps Quad 405 Mono Blocks.
Speakers. TBC
Home Cinema.UNDER CONSTRUCTIONDAC/Pre Amp. Denon AVC X3700H.BDP/Streamer. Panasonic DP-UB820EB / Apple TV4K.Display. Optoma UHD51 / DIY False Black Window Screen.
Power Amps. 2 x Nakamichi AVP1.
Front Speakers. DIY Baby Celestion Ditton 66. Surround Speakers. Celestion Ditton 11. Subwoofer. BK Electronics P12 300SB PR.
Old Gallery. http://theartofsound.net/forum/showt...-of-the-70%92s
Gary, just re-reading this thread and what do you mean when you say "the woofers have their domes rotten away" - do you mean there is a problem with the dust caps or something more? Do you have any pictures?
Frankly, if you can get them to Hampshire, I'd be happy to repair them for you.
