I'm Thommy.
How about this:
http://www.ebay.co.uk/itm/Valab-Pure...-/321884679696
Valab Pure Silver litz wire 25/0.12mm strands and only £5 a metre.
If you want to make a really good pair of cables, for a very small sum get the desired length of that stuff and run just one line in each direction.
An easy way to get some possible benefits from damping/insulation run each of these wires inside it's own 5mm silicon hose. Put both hoses into a section of 12mm braid and attach some fat RCA plugs on the end.
I have found these Cardas copies to be extremely good value for money:
http://www.ebay.co.uk/itm/8pcs-Pure-...-/331090817285
They aren't actually pure copper, but brass (which is mostly copper) but for under £1.50 each offer outstanding valueand they fit the 12mm braid nicely.
4% silver solder makes a big difference. Here's 15 metres for under 8 quid:
http://www.ebay.co.uk/itm/5m-SOLDER-...-/110551587168
I bought some a couple of years ago and am only onto the second spool recently after building 4 DACs, 3 amps and a pile of cables.
Speakers: Wilmslow Audio Prestige, ATC SCM11, B&W 602S02
Cables: Missing Link Cryo Ref, handmade pure silver Litz braid, Van Damme Blue
Amps: Hypex nCore400, DIY SET EL34/ECC83, DIY PP KT88 Monoblocks, Hypex UcD400 HG
DACs: Quad Deck DDDAC, Single Deck DDDAC, Modified Chinese 9018, DIY Russian TDA1543 DAC
Turntable: Technics SL1200 Modified, linear PSU, Paradise Phono Preamp
Interconnects: Handmade silver Litz, Missing Link Alaqeia
Preamps: DIY - buffers, LDR attenuators, stepped pots
Mains: Balancing transformers, RF filters, handmade cables
Does anyone have a link for the ms plugs or is it an eBay job?
My System
John Wood KT88 Amp.
Paradise Phono Stage
Sony TTS-8000 Turntable.
PMAT-1010 MK6 Tonearm.
Ortofon Cadenza Bronze
Sony X555ES Cd Player
Yamaha NS1000m Speakers
Iget mine from here Jaime http:// http://www.ebay.co.uk/itm/MS-Audio-Star-Line-Silver-Plated-Tellurium-Copper-RCA-Plugs-2-Pair-/321871242323?hash=item4af1056453
But be patient as they take a month or so to arrive
CDP: Primare CD31 Amp: Audio Note Oto SE DAC: M2Tech Young & Van Der Graaf PSU Speakers: Tannoy Cheviots
Streaming: bespoke Korus server with SOtM soundcard, AudioQuest Jitterbug & Furutech GT2 USB cable
Speaker Cable: Tellurium Q Black - Interconnects: MS Audio/Klotz MC5000
Come Chill With Me...
https://www.mixcloud.com/orbscure
http://theorbscureddj.blogspot.co.uk
+ play + enjoy + float + dream +
Cheers Pete apparently i'm helpful but crap at links
Available in 3 flavors, I have Rhodium http://www.ebay.co.uk/itm/MS-Audio-S...item33a9bb28f1 and also available in Gold http://www.ebay.co.uk/itm/MS-Audio-S...item4af1d26e02
Darren.
Listening Room.UNDER CONSTRUCTIONTurn Table. Garrard 401, Reso Mat, 2 Tier Slate Plinth, DIY Hadcock GH242, Nick G modded Lentek, Denon DL-103.
Pre Amp. Croft Super Micro2. Power Amps Quad 405 Mono Blocks.
Speakers. TBC
Home Cinema.UNDER CONSTRUCTIONDAC/Pre Amp. Denon AVC X3700H.BDP/Streamer. Panasonic DP-UB820EB / Apple TV4K.Display. Optoma UHD51 / DIY False Black Window Screen.
Power Amps. 2 x Nakamichi AVP1.
Front Speakers. DIY Baby Celestion Ditton 66. Surround Speakers. Celestion Ditton 11. Subwoofer. BK Electronics P12 300SB PR.
Old Gallery. http://theartofsound.net/forum/showt...-of-the-70%92s
Thanks everyone, I've now got everything I need to start.
Much appreciated.
My System
John Wood KT88 Amp.
Which one of these three versions is the best? I am about to order one for my klotz but confused on these optıons. What kind of sonic differences should i expect?
Thanks
I don't like plugs with small contact areas. You just know they'll chafe through the plating on the sockets eventually and the conductive cross section is limited.
