I've ran antivirus nothing found. Nothing loads, if I click on Google it's just one eternal egg timer spinning round. The computer is fairly new and good spec so why all this instability ?
Do a system restore to a date prior to the problem.
Could be a bit of malware hogging resources.
Are you using Windows, if so which one?
Right-click (or press and hold) the Start button, and then select Control Panel.
Search Control Panel for Recovery.
Select Recovery > Open System Restore > Next.
Choose the restore point related to the problematic app, driver, or update, and then select Next > Finish.
Note
If you’re not seeing any restore points, it might be because system protection isn’t turned on. To check, go to the Control Panel, search for Recovery, and then select Recovery > Configure System Restore > Configure and make sure Turn on system protection is selected.
OK. Might be best to run some anti malware first.
Try downloading Malwarebytes and running it. It's free here: https://www.malwarebytes.org/mwb-download/
I also use AdwCleaner. Both do similar things, but seem to find different bugs: https://toolslib.net/downloads/viewd.../1-adwcleaner/
They should detect that you are using Windows 10 and give you the right version automatically. Try both and see if the problem has gone. Both are free to use. If not a restore may help.
Cheers guy - it's F1 at da mo so will try later
Right Geoff, I managed to download the free malwarebytes, ran it and result was zero - clear. Then clicked on Google Chrome and has let me in as normal hence I've updated thread. Before i couldnt get anything to load Computers do my head in ! Wouldn't be surprised if it's daft stuf going on in the background with Windows 10 but who knows
I've known Windows updates to bugger things up, then they realise there's a problem and you get a fix in the next update.
