a couple of good freeware applications herw.. first 2
http://www.cpuid.com/softwares.html
I'm Alex.
Thanks, I already have the CPU-Z, but not the other three, will look at them.
Correction! just looked at HWMonitor, yes, used that before.
Spendorman
the other program gives you this
I'm Alex.
Alas ive had an accident with one of the hdds... I fell over and knock the case when it must have been writing its now become write protected. Its actually not write protected but seems to think it is...its gon raw and cant be fixed i think... Fortu!ately it wasnt expensive but annoying. Im getting unsteadyer by the week it seems lol
I'm Alex.
Sorry to hear that, if you feel your getting more unsteady, let you your GP know.
Was this the new 7200 RPM Seagate?
Have you treid Crystaldisk info. might tell you if what's wrong.
Perhaps get the info off it and try wiping with GParted.
Spendorman
Aye,it was one of the baracudas. Ive tried a few things and got what was on it with easus. Not that i wanted it tbh. Though if i did it i might be able to convert it back to ntfs from raw but it just says write protected. I used diskpart and its not write protected. Also tried scans and repairs etc but it doesnt move. Only thing i can think is its buggered. Shame but such is life..
Seeing doc for other faulty bits Alex, so will add it to the list.... I might be a write off
I'm Alex.
I've had something similar with HDD's but not this exact thing. What might be worth trying is putting it as master in a machine, booting the machine from a CD of Gparted and wiping/ formatting.
Yes, getting older things happen. I'm been putting off going to my GP with a few questions. I used to get annual MOT's, they seem to have stopped doing that.
Spendorman
I will hang on to it till time comes i lay hands on a machine that has a 3.5" bay and try that. If not then its a clock or grinder conversion for it lol
I'm Alex.
Ah, so you have all those laptops but no desktop / tower machine. Shame, they are so versatile. Often dumped in the street or on a skip.
A have a couple much like these:
http://www.ebay.co.uk/itm/Refurbishe...-/311686348853
And one like this:
http://www.ebay.co.uk/itm/HP-dc5800-...-/331955904018
All three bought on ebay for silly money.
Spendorman
