Page 194 of 200 FirstFirst ... 94144184192193194195196 ... LastLast
Results 1,931 to 1,940 of 2000
Thread: Computer Disaster Corner
  1. #1931
    Quote Originally Posted by spendorman View Post
    I know almost nothing about tablets and Android, a quick Google resulted in this
    https://www.lifewire.com/unzip-files-on-android-4178981
    If I had to do it, would probably send the Zip file to a Windows PC and unzip it there.
    Unfortunately this didn't work or Winzip, all I get is unable to access this type of file,
  2. #1932
    I'm Adrian.
    James, just thinking outside the box and trying to make your life easier, do you not have a friend or friendly neighbour with a Windows or Mac machine that could download the file, unzip it and put on your Memory Stick for you? It might save a load of hassle and frustration.
  3. #1933
    there are friendly neighbours??
    I've asked my niece but she's either at college or work
  5. #1935
    My work email is sending out spam, I changed password, but I keep getting about 50 messages a day saying "You getting this message because an error detected while delivered your email."
  6. #1936
    Using an HP printer? It may get more expensive!
    https://www.theguardian.com/money/20...nter-cartridge
  7. #1937
    I've a hp printer. It's a laser too. Bastards
    i might add the software never worked so it was not installed. printer is just used inside windows; so dunno if it will be affected. i am still on the original toner and ive had it for several years
    I guess blocking firmware updates may help. I did that on my Canon when I got it.
  10. #1940
    ive no software marked hp so nowt really to update that i can see.. i just ask it to print something and then select the printer
