Page 163 of 200 FirstFirst ... 63113153161162163164165173 ... LastLast
Results 1,621 to 1,630 of 2000
Thread: Computer Disaster Corner
  1. #1621
    I have that router and set a fixed ip for my streamer, I think they added that ability with the firmware that came out just before I started my Talktalk account a couple of months ago.
    Go to My Devices, scroll down to Manage Advanced Settings then scroll down to the device ( in your case Volumio ) and then click on Reserve IP in the green box, then click apply.
    I think I rebooted the router after that just to make sure the change stuck.
  2. #1622
    Take a note of ur firmware no Mike and how/where u did it. I might have old firmware.
    Don't recall seeing that
    Dunno if this helps
  4. #1624
    Cheers. Think that's different. Sure mine is 400
    Will check tomorrow. Not sure how u get the firmware update yet lol
    I'm checking on that too, but any post I read just seems to suggest it gets pushed to the routers automatically
  6. #1626
    Ah, may just have to be patient then. Thanks
    Have you rebooted it recently? If not try that as it might force an update
  8. #1628
    Yup once. Try it again tomorrow. Maybe they didn't know I had it. Might take a day or two.
    Streaming a film and still getting nearly 27 wifi upstairs. Would have been 6 with old router at best
    Yeah think they try a push every 24 hours or so.
    They seem to be a lot more stable than the BT I had previously.
  10. #1630
    My last talk talk router was very stable but the WiFi was crap. Even in same room it dropped off alarmingly with distance.
    These big buggers seem mu h stronger
