Future is bright, great and positive.
Power regenerator on 1800 Wts named SINWEX (brand VishLabs, made in Ukraine) was installed in my System about 3 months ago. If somebody has interest - I may drop more information. Review on Ukrainian language is here.
That looks an interesting device. I'm always interested in how these things perform. Why not write a few words so that we can all see how it performed in your system?
Well, this device is mostly for Music Lovers, definately, it's not Audiophilic. SINWEX - it's SInusoidal Noise Wideband EXtractor.
Technical Specifications:
Output:
Power - up to 1800 VA
Voltage - 105-245 Volts
Current - 8 Amps
Frequency - 50 or 60 Hz
Peak - 8 Amps
Distortion (THD+N) - 0.3%
HF noise - 22mV RMS
Input:
AC input range - 190-260 Volts
Frequency input - 50/60 Hz
Input capacity - ap 2100VA
Power consumption - 20 Watts (with no load)
General:
W x H x D - 443x 100 x 320 mm
Weight - 19 kg (unboxed)
Cooling system - heatsink
Design:
SPWM 23.4KHz
CPU 12MHz
Output H on 4 IGBT
DT 300ns
Transformer output - balanced Power line 115+115V with central tap.
No matter what kind of distortion on Input of device - you will get clean power with correct sinusoida and required voltage on output, which can be easily regulated by you.
Main gain of device in sound - unbeleivable incriment of Dynamic Range. You may listen Your System at night on low volume level, no matter how thin your walls and where are sleeping neighbours. Layers of records will be better recognizable, breathe of music will impress you. Positioning of musical sources (instruments or voices) will be more accurate. You may switch on whole Your System pushing just only one button on SINWEX.
I hope, this information will help you, photos you may find in my review, link is above.
Very interesting and a great device to run turntables that require a 50hz frequency to generate the correct rotation speed
Well, I would like to share my own experience regarding subject.
I have vintage vynil player of German brand ELAC, model Miracord 50H, made in 1974.
I've bought twice cartridge to replace original one from ebay like this (i.e. replica): https://www.ebay.com/itm/26030955624...sAAOSwbFhgoi8c
but this cartridge is shitty, it worked a couple months before starting of self-distraction.
I had to smoke subject during my previous vacation and found interesting information about Japanese brand JICO - https://www.jico-stylus.com/.
These guys products replicas for vintage vynil players.
My player receives 2 models: ST-444-17 and ST-344-17 (last one is higher).
As you may see it costs 56 USD (https://www.jico-stylus.com/shop/?fi...-number=STS344) plus delivery 27 USD, thus I paid 83 USD totally.
Alternative originals?
Well, I saw used ST-344-17 for unbelievable 200 USD plus delivery.
In result I ordered 1 JICO cartridge, I got it few days ago and now I have pleasure again to listen my small collection of vynil plates.
Nice to see you back, and at least getting the turntable playing again, but you don't say anything about the Gutwire cable you purchased, interconnect, speaker cable, power cord? I know you have replaced a few cables recently, maybe the last year or so
Always very good to read about your journey Sergio. Thanks for the update.
Cabling is on march now!
I've bought suddenly 3 GutWire Cables:
1.Top Balance Interconnect Consummate
2. Power Cable SV-16
3. AES/EBU Digital Interconnect SD-3SE
Power Cable SV-16 was installed before power regenerator SINWEX,
I had to use adaptor, because I had only european socket. But today I completed replacement of socket from European type to American.
