Calling all digital cable experts - SPDIF termination question
Hi, sorry if this has been discussed before.
I've been thinking about digital coax cables today and in particular the argument of proper 75 Ohm termination.
To set the scene, the basic argument is that for the best SPDIF signal transfer, all the plugs, sockets and cables in the signal path should be true 75 Ohm to make sure that reflections in the cable are minimal. I hear that most phono plugs and sockets are not true 75 Ohm and even the ones that claim to be are not likely to actually be true 75 Ohms. To get true 75 Ohms I hear you need to use BNC connectors.
So, if BNC connectors are a fairly certain way of making the best possible connection, then the most productive upgrade to SPDIF equipment would not be buying expensive SPDIF cables with expensive phono connectors, it would be by swapping the phono sockets for BNC and getting a BNC to BNC coax cable. Surely this would be cheaper and better in the long run as it would provide better signal transfer?
I then started to think outside the box a bit. When thinking about this from an electrical conductivity point of view, putting any socket and plug connection in the signal path will degrade the signal slightly. Some are better than others. The best ones are usually expensive. So removing the phono or BNC connection out of the signal path all together would surely be better and cheaper.
So my main question is this; Would de-soldering the sockets from the source and receiver and directly soldering a good quality true 75 Ohm coax cable to the PCB at either end be the best solution or would this not provide a true 75 Ohm connection due to some reason I'm not aware of?
Obviously the results wouldn't be very practical due to the permanent connection but we'll ignore that for now.
I'd also tike to understand how much difference in sound quality there is likely to be between using a Phono connection, BNC, or a directly soldered connection.
I'm hoping to get some solid scientific facts about this to help me understand what's actually best. Hopefully this won't turn into a big argument like I know it would on other forums.
Thanks.
Source: Apple TV 4K - DAC: Beresford Bushmaster Mk II - Preamp: CI AudioPLC-1 Mk II - Power Amps: Musical Fidelity 550K mono blocks - Speakers: Wharfedale Opus 3 - Cables: Mark Grant etc - Misc: Belkin PF30 mains filters.
