worked for me Barry
Think this is the appropriate paragraph
Recall I had mentioned that Origin Live utilized a unique lead-out cable. They allude to its superiority on their site, but give no details. It turns out that, while 99% of the phono cables out there use twisted pairs, spirals, or braids, OL uses co-ax—that is, the outer screen carries one leg of the circuit. Baker made that choice, like every other aspect of his design, for purely sonic reasons. With a single-ended (RCA) input phono stage, the screen helps lower the noise floor by taking RFI to ground. With the balanced input Aqvox, the screen became an antenna. Ooops. There was an easy fix—I wrapped the cables with foil, and connected that to the Aqvox ground post, and Rush retreated to his rat-hole. Ugly, but the sound was now excellent—the cable is indeed quite fine—but Baker asked that I return the tonearm so he could be sure nothing internal was amiss.
next couple of paragraphs if of any help
What I heard was not just Rubinstein; Rush Limbaugh was carrying on about feminazis, li'bruls, and how well the war was going, despite what the drive-by media keeps putting on the 6 o'clock. Talk about RFI hell. It took a few emails back and forth across the Atlantic to figure out what was going on. It was mid-summer here in the desert, and to beat the heat I had replaced my Herron tube phono stage with the solid-state Aqvox II CI, largely on the recommendation of PFO colleague John Zurek (here is a link to his PFO review). While I can enthusiastically second everything he wrote about it, due to the unique circuit design and RCA to XLR adaptors, it is fussy about the phono cabling. On the Aqvox site there is a list of tonearms that have checked out fine with their system. Stock Regas are not suitable (no separate ground lead) but rewired ones are—my Incognito rewired RB250 had not had any problems at all. Just about every other tonearm imaginable makes the OK-list—except Origin Live.
Not long after that, another wooden box arrived from OL, another Illustrious with of all things, a standard 5 pin "DIN" socket in the arm pillar, and a DIN to XLR cable. These options were not on the OL web-site before I managed to get Mark at OL and Norman at Aqvox equally exasperated, but they are available now. So, if you want to put a Kimber or Hovland (I am blessed with both) or whatever cable on an Origin Live arm, you can do so. Conversely, if you have known or possible RFI problems and/or a single ended (RCA plugs) system, the stock OL co-ax will be just the ticket. One of the advantages of small-firm sourced products is flexibility in meeting customer needs. Assuming the substitute OL cable was a one-off accommodation and not a standard item, most of my listening with the Illustrious and Aqvox was done with the very fine Xaus Phono from Zu Cables, terminated by those kind folks exactly as recommended by Aqvox. Come the cooler months, I switched back to the single-ended, tube-based Herron Audio gear with the Kimber and Hovland cables. Brilliant!
Dunno I only look at the pictures
I'm charles.
