Orbe arrived today and sounds amazing. My amp is a Music Fidelity 3.2 integrated amp and speakers are Monitor Audio Gold floor standers.
What phono stages would you recommend I listen to. I have a £600 budget.
Thanks
Thanks
NVA Phono 2. I am using one with my Orbe SE. Cracking!
I'm Shaun.
Glen Croft unit although M/M only. Five hundred quid and totally hand built. Also, a valve unit of impeccable pedigree.
http://www.croftacoustics.co.uk/RIAA.html
Firebottle.
Hunter S Thompson
Graham Slee Era Gold V
http://www.gspaudio.co.uk/eragoldvphonostagepreamp.htm
Chris
Common sense isn't anymore!
I'm Bob.
Icon Audio PS 1.2 (used), should come in for circa £450 - £550. Everything is replaceable from Icon at Leicester should you need anything (unlikely, they're built like a tank) and you'll sell it for what you paid for it in a couple of years time if you want to move up. All valves are available at sensible prices too! It'll add a touch of warmth to the MA speakers and build on the considerable soundstage and quality bass your deck is famous for.
I had one for about 4 years whilst I scraped the cash together for a PS 3. I tried a few solid state designs before shelling out for the PS 3 but they couldn't even get close.
Good luck whatever you decide to go with.
Source: Orbe SE / SME IV / Cadenza Bronze
Source: WD NAS / Cyrus Stream X2 / Chord DAVE
Source: Oppo UDP-205 (CD/DVD-A/SACD)
Amplification: Icon Audio PS 3 Sig Phono + Audio Research LS27 + Musical Fidelity A5cr Power Amp
Loudspeakers: ProAc Response D28
Cables/stands: Mark Grant G1500HD + Linn K20 + Cat 5e
Other bits: Okki Nokki keeping things clean
I'm mark.
Need to know what cartridge you intend to use.
The best Trichord you can afford is a very flexible place to start 2nd hand. I'd start Dino/NCPSU .
AC POWER
AMPS
SPEAKERS
Wharfedale Evo 4.4
DAC
TURNTABLE
PHONOSTAGE
DIGITAL
MUSIC PLAYBACK
Ipad Roon Remote.
SPEAKER CABLES
INTERCONNECTS
I'm scott.
project rs phono
The list is endless.
