Results 21 to 30 of 45
Thread: ‘Little Bear’ Moving Coil Step Up Preamplifier T8-1
  1. #21
    Quote Originally Posted by lurcher View Post
    More likely a 2SK184 jfet.
    Thanks Nick.
    Have had one of these for some time but never got round to trying it. So with the sony having a decent mm stage i decided to give it a whirl.
    First i payed a side of the wallflower album on my mc section of the mani then connected up the bear .... 1st problem was a bit of hum and this unit doesnt have an earth post...hmmm. Managed to put tt earth under one of the rca s and that got rid of most of it and moving it around most of the rest to an acceptable level.
    Replayed record and it sounded quite good. Not at the level of the mani by a bit but acceptably listenable to and for 20 quid a good option on a budget when running a mc cart. It was clean and lucid in its presentation although lacked a bit of drive and sparkle.
    Could live with it if needed to but not on a par with the little man
    I've just gone and bought one of these little phonostages, mainly for a little fun and also for experimental purposes.
    PRE
  4. #24
    I kinda fancy doing mine up and see how far I can take it without spending hundreds. Reckon just changing the caps and some resisters would be enough, although a complete external psu could be fed into it if one wanted to.
    i have the same plans Grant, probably spend a little time getting to learn it's "house" sound and then start to modify. Any thoughts on how yours sounds?
    PRE
  6. #26
    Its pretty good tbh, but lacking maybe a little punch, but that could come up with better componets. although a simple design, It could be a winner. Still fancy an offboard psu would be good. just have to byepass the rectification section perhaps. some shielding, a earth post and maybe fit it in another box. a minimum of 30/40 first way, or maybe 120 the second but it may well raise it. would likely try the cheap way first and see if it did improve.
    ? What ? You been on the single malt ? I've got the Ankaka PSU so may choose use that as a decent external PSU. Adding an additional earth should be easy do, probably something you could buy a couple of quid and then simply drill into the case?
    PRE
  8. #28
    Caps will cost a good few quid for decent ones...there are 8 in there.. thats why I said 30/40..... if you then wanted to go nuts you could go to next stage.
    Ah I see. You could indeed spend lots of money, but for me its just a bit of fun. I'm not going to be spending loads on it. I also just ordered a little bear valve pre amp for <Ł30.
    PRE
  10. #30
    Ordered some parts from RS.. less than a tenner all in, so well will see if it improves it any b4 I do anymore thinking.
